-1
when trying to change the ownership of a directory i get the error:
chown: changing ownership of '/home/tadpoles': Operation not permitted
I even get the above message when i do sudo -s and run it as root.
Here is the command i try to run:
sudo chown toadmanager /home/tadpoles
Also, here is the perms of the directory when i run ls -l: (SharedFolder is in the directory and it also cannot be modified)
total 32
drwxr-xr-x 2 root root 32768 Feb 16 12:23 SharedFolder
I am fairly new to ubuntu and linux in general so any help is appreciated, i also already looked up some other guides and chgrp did not work either. I should also mention that this directory is on a different drive which is mounted to /home/tadpoles and the file system is vfat
If you could run this command and post the output to the original question, it might help.
    cat /etc/passwd | grep toadmanager
If you get no output from the command it means that toadmanager is not a user on your system.
You can search for Users in the Activities panel in Ubuntu 20.04 LTS, unlock the application, and use the green pushbutton to "Add User" for toadmanager.
mondotofu
  • 817
Solved, i had a vfat file system so i went in a reformatted the drive in ext4. Everything works properly now!
Thanks Paul Benson
