I have a Windows and Ubuntu dual boot. My Windows is not working anymore. I already have a back up of the files I had on Windows. Now I want to format 80% of the Windows partition to expand my Ubuntu partition. I want to leave some unallocated space to install Windows again in the future.
With GParted I already selected "unmount" on the Windows partition. Now it looks like a part of it appears as unallocated and the other is still there.
This is how the GParted looks like now.
This is the information about the Windows partition now.
I read that I will need to boot from a USB or CD, unmount the HDD Ubuntu partition and resize it using GParted, but the Windows partition doesn't look good now and I am afraid of doing something wrong. How should I proceed?
Could work but the partitions are in the wrong order for it to have good result. Once the windows partition is gone and divided up then grub will fail on your existing install as the location on the drive will change for the partition number. Really your best option is to backup your home on the Ubuntu install and re-install with a corrected partitioning as you want it to be. Leaving space at the start of the drive for a new Windows install. If installing Windows again it will mess up the boot loader of Grub, then this will need a re-install. So the Windows should be installed onto that first partition on the drive you are allowing for too first before the Ubuntu, then everything is in place as you want it to be with both OSs installed in working configuration.
