I'm a beginner with Ubuntu, booting it via usb in order to see if I can recover files from my hard drive after a crash. I clicked on my hard drive in order to mount it, and got "Unable to mount 151 GB Filesystem" as the title of an error message. It then goes on to say:
Error mounting: mount exited with exit code 13: ntfs_attr_pread_i: ntfs_pread
failed: Input/output error
Failed to read NTFS $Bitmap: Input/output error
NTFS is either inconsistent, or there is a hardware fault, or it's a SoftRAID/FakeRAID hardware. In the first case run chkdsk /f on Windows then reboot into Windows twice. The usage of the /f parameter is very important! If the device is a SoftRAID/FakeRAID then first activate it and mount a different device under the /dev/mapper/ directory (e.g. /dev/mapper/nvidia_eahaabcc1). Please see the 'dmraid' documentation for more details.*
Does this indicate a total hard drive failure, or is there a way to correct this error and access my files? Tnx JW
