I want to install default-libmysqlclient-dev using
sudo apt-get install default-libmysqlclient-dev
But I get this output
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: default-libmysqlclient-dev : Depends: libmysqlclient-dev but it is not going to be installed E: Unable to correct problems, you have held broken packages.
So I try a different approach using aptitude
sudo aptitude -f install default-libmysqlclient-dev
And now I get
The following NEW packages will be installed:
  default-libmysqlclient-dev libmysqlclient-dev{ab}
0 packages upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 1,126 kB of archives. After unpacking 6,959 kB will be used.
 libmysqlclient-dev : Depends: libmysqlclient20 (= 5.7.21-1ubuntu1) but 5.7.27-0ubuntu0.18.04.1 is installed
The following actions will resolve these dependencies:
 Keep the following packages at their current version:
  1. default-libmysqlclient-dev [Not Installed]
  2. libmysqlclient-dev [Not Installed]
Accept this solution? [Y/n/q/?]
After accepting the solution (Y), I get this output
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
So nothing was installed
System Information
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Ubuntu 18.04.2 LTS"
aarch64
I think for these specs, I have package available for download
How can I troubleshoot this?
EDIT
Command
grep ^deb -r /etc/apt/ --include=*.list
Outputs:
/etc/apt/sources.list:deb http://ports.ubuntu.com/ubuntu-ports/ bionic main universe restricted multiverse
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu bionic-security main
/etc/apt/sources.list:deb http://ports.ubuntu.com/ubuntu xenial-security main
/etc/apt/sources.list.d/cuda-10-0-local-10.0.326.list:deb file:///var/cuda-repo-10-0-local-10.0.326 /
/etc/apt/sources.list.d/visionworks-sfm-repo.list:deb-src file:///var/visionworks-sfm-repo /
/etc/apt/sources.list.d/visionworks-sfm-repo.list:deb file:///var/visionworks-sfm-repo /
/etc/apt/sources.list.d/visionworks-tracking-repo.list:deb-src file:///var/visionworks-tracking-repo /
/etc/apt/sources.list.d/visionworks-tracking-repo.list:deb file:///var/visionworks-tracking-repo /
/etc/apt/sources.list.d/visionworks-repo.list:deb-src file:///var/visionworks-repo /
/etc/apt/sources.list.d/visionworks-repo.list:deb file:///var/visionworks-repo /
fabda01
  • 263
You should fix your repositories. Change the following lines of /etc/apt/sources.list
to the following:
deb http://archive.ubuntu.com/ubuntu bionic main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu bionic-security main restricted universe multiverse
Then run sudo apt-get update to update package lists and proceed with installation of latest upgrades to Ubuntu 18.04.5 LTS by sudo apt-get dist-upgrade .
N0rbert
  • 103,263
