I want to install Ubuntu on a i7-8565U @1.8GHz and 20GB RAM with 2 SSD's: 1 nvme and 1 SSD. What's the best setup regarding these 2 disks? I don't want to dual boot.
I am thinking of using the nvme for boot / root / swap and the SSD for /home. Is that ok?
FedKad
  • 13,420
Both drives are solid state drives, and the NVMe SSD is the faster of the two drives. NVMe SSDs currently run in the 256GB/512GB/1TB size range. Depending on the size of the SSDs, you can install everything in a single partition on the NVMe SSD and split the home directory into two different partitions or use the 2nd SSD for data storage.
karel
  • 122,292
  • 133
  • 301
  • 332
