My /dev/sda6 says I only have 4.7G available but still use% is 99? It does not make sense.
Can someone help me with this?
waybackdrm@dolansroadbike:~$ df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            3.8G     0  3.8G   0% /dev
tmpfs           784M  2.5M  781M   1% /run
/dev/sda6       260G  242G  4.7G  99% /
I try the following:
sudo apt-get autoremove
sudo apt-get clean
doesn't seem to do anything?
Any feedback? also let me know if I need more screenshots?
phuclv
  • 760
Because some of the space is reserved. You can check it by running
tune2fs -l /dev/sda6 | grep 'Reserved'
By default 5% will be reserved for the root, which is 260G * 0.05 = 13G. That means the available space to you is only ~247G. ext4 itself also needs some space for its metadata, so you're already almost full
To reduce the reserved space run tune2fs -m$PERCENT $PARTITION. For example to reduce it to 1% in your case run
tune2fs -m1 /dev/sda6
But it's only a temporary solution. Having a full disk is not a good idea anyway since there isn't enough space for a contiguous region for new files or to move old files around, so fragmentation will increase significantly. You should consider cleaning up your disk and/or upgrade disk space
See
phuclv
  • 760
