I am trying to change my cpu max frequency. I have tried with tlp, cpupower, and the solution in this same forum (the one that goes: for x in /sys/devices/system/cpu/*/cpufreq/; do echo 1700000 | sudo tee $x/scaling_max_freq; done)
None of these have helped me. My frequency range is set from 0.8 to 2.2 GHz. I want to change my max freq. this is the info from cpupower:
driver: intel_pstate
  CPUs which run at the same hardware frequency: 0
  CPUs which need to have their frequency coordinated by software: 0
  maximum transition latency:  Cannot determine or is not supported.
  hardware limits: 800 MHz - 2.20 GHz
  available cpufreq governors: performance powersave
  current policy: frequency should be within 800 MHz and 2.20 GHz.
                  The governor "powersave" may decide which speed to use
                  within this range.
  current CPU frequency: Unable to call hardware
  current CPU frequency: 800 MHz (asserted by call to kernel)
  boost state support:
    Supported: no
    Active: no
PLEASE HELP ME! thanks! :)
Doug Smythies
  • 16,146
