Ubuntu 16.04.5 LTS
I want to upgrade to newer Ubuntu and newer OpenSSH, but it is failing. Any ideas how to get past this?
do-release-upgrade
Traceback (most recent call last):
  File "/usr/bin/do-release-upgrade", line 11, in <module>
    from UpdateManager.Core.MetaRelease import MetaReleaseCore
  File "/usr/lib/python3/dist-packages/UpdateManager/Core/MetaRelease.py", line 25, in <module>
    import apt
  File "/usr/lib/python3/dist-packages/apt/__init__.py", line 23, in <module>
    import apt_pkg
ImportError: /usr/lib/python3/dist-packages/apt_pkg.cpython-36m-x86_64-linux-gnu.so: symbol _ZN13debListParser12ParseDependsEPKcS1_RNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEES8_RjRKbSB_SB_RKS7_ version APTPKG_5.0 not defined in file libapt-pkg.so.5.0 with link time reference
Error in sys.excepthook:
  File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 63, in apport_excepthook
    from apport.fileutils import likely_packaged, get_recent_crashes
  File "/usr/lib/python3/dist-packages/apport/__init__.py", line 5, in <module>
    from apport.report import Report
  File "/usr/lib/python3/dist-packages/apport/report.py", line 30, in <module>
    import apport.fileutils
  File "/usr/lib/python3/dist-packages/apport/fileutils.py", line 23, in <module>
    from apport.packaging_impl import impl as packaging
  File "/usr/lib/python3/dist-packages/apport/packaging_impl.py", line 23, in <module>
    import apt
    import apt_pkg
Original exception was: Traceback (most recent call last): File "/usr/bin/do-release-upgrade", line 11, in <module> from UpdateManager.Core.MetaRelease import MetaReleaseCore File "/usr/lib/python3/dist-packages/UpdateManager/Core/MetaRelease.py", line 25, in <module> import apt File "/usr/lib/python3/dist-packages/apt/init.py", line 23, in <module> import apt_pkg ImportError: /usr/lib/python3/dist-packages/apt_pkg.cpython-36m-x86_64-linux-gnu.so: symbol ZN13debListParser12ParseDependsEPKcS1_RNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEES8_RjRKbSB_SB_RKS7 version APTPKG_5.0 not defined in file libapt-pkg.so.5.0 with link time reference
sudo apt update
Hit:1 http://azure.archive.ubuntu.com/ubuntu bionic InRelease
Get:2 http://azure.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
Get:3 http://azure.archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB]
Hit:4 http://security.ubuntu.com/ubuntu bionic-security InRelease
Fetched 163 kB in 0s (618 kB/s)
Reading package lists... Done
Building dependency tree
423 packages can be upgraded. Run 'apt list --upgradable' to see them.
sudo apt upgrade
You might want to run 'apt-get -f install' to correct these.
 grub-pc : Depends: grub-common (= 2.02-2ubuntu8.21) but 2.02~beta2-36ubuntu3.18 is installed
 grub-pc-bin : Depends: grub-common (= 2.02-2ubuntu8.21) but 2.02~beta2-36ubuntu3.18 is installed
 grub2-common : Depends: grub-common (= 2.02-2ubuntu8.21) but 2.02~beta2-36ubuntu3.18 is installed
 libpython2.7-stdlib : Depends: libreadline7 (>= 7.0~beta) but it is not installed
 libpython3.6-stdlib : Depends: libreadline7 (>= 7.0~beta) but it is not installed
 python-apt : Depends: libapt-inst2.0 (>= 1.6.5~) but 1.2.27 is installed
              Depends: libapt-pkg5.0 (>= 1.6.5~) but 1.2.27 is installed
 python3-apt : Depends: libapt-inst2.0 (>= 1.6.5~) but 1.2.27 is installed
 python3-cryptography : Depends: python3-asn1crypto (>= 0.21.0~) but it is not installed
                        Depends: python3-idna (>= 2.1) but 2.0-3 is installed
 python3-gdbm : Depends: libgdbm5 (>= 1.14) but it is not installed
 python3-newt : Depends: libnewt0.52 (= 0.52.20-1ubuntu1) but 0.52.18-1ubuntu2 is installed
 systemd : Depends: libsystemd0 (= 229-4ubuntu21.2) but 237-3ubuntu10.44 is installed
 udev : Depends: libudev1 (= 229-4ubuntu21.2) but 237-3ubuntu10.44 is installed
E: Unmet dependencies. Try using -f.
sudu apt-get -f install
  File "/usr/lib/python3.6/dbm/gnu.py", line 4, in <module>
    from _gdbm import *
ImportError: libgdbm.so.5: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
Traceback (most recent call last): File "/usr/lib/python3/dist-packages/CommandNotFound/CommandNotFound.py", line 7, in <module> import dbm.gnu as gdbm File "/usr/lib/python3.6/dbm/gnu.py", line 6, in <module> raise ImportError(str(msg) + ', please install the python3-gdbm package') ImportError: libgdbm.so.5: cannot open shared object file: No such file or directory, please install the python3-gdbm package
Traceback (most recent call last): File "/usr/lib/command-not-found", line 27, in <module> from CommandNotFound.util import crash_guard File "/usr/lib/python3/dist-packages/CommandNotFound/init.py", line 3, in <module> from CommandNotFound.CommandNotFound import CommandNotFound File "/usr/lib/python3/dist-packages/CommandNotFound/CommandNotFound.py", line 9, in <module> import gdbm ModuleNotFoundError: No module named 'gdbm' Error in sys.excepthook: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 63, in apport_excepthook from apport.fileutils import likely_packaged, get_recent_crashes File "/usr/lib/python3/dist-packages/apport/init.py", line 5, in <module> from apport.report import Report File "/usr/lib/python3/dist-packages/apport/report.py", line 30, in <module> import apport.fileutils File "/usr/lib/python3/dist-packages/apport/fileutils.py", line 23, in <module> from apport.packaging_impl import impl as packaging File "/usr/lib/python3/dist-packages/apport/packaging_impl.py", line 23, in <module> import apt File "/usr/lib/python3/dist-packages/apt/init.py", line 23, in <module> import apt_pkg ImportError: /usr/lib/python3/dist-packages/apt_pkg.cpython-36m-x86_64-linux-gnu.so: symbol ZN13debListParser12ParseDependsEPKcS1_RNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEES8_RjRKbSB_SB_RKS7 version APTPKG_5.0 not defined in file libapt-pkg.so.5.0 with link time reference
Original exception was: Traceback (most recent call last): File "/usr/lib/python3.6/dbm/gnu.py", line 4, in <module> from _gdbm import * ImportError: libgdbm.so.5: cannot open shared object file: No such file or directory
sudu apt list --upgradable
    from _gdbm import *
r4v3n6
  • 33
