I had my office laptop (acer singleboot)at my home which i upgraded (sudo apt update) after a long time. ununtu eduunbuntu image (bootscreen)18.04. Then after i restart it is not booting.
Failed to open \EFI\BOOT\mmx64.efi - Not found
To fix this you will need to have a Live USB or Live DVD handy. Fortunately, it's not too difficult. Here's what you need to do:
  1. Boot the machine using the Live USB / Live DVD and select "Try Ubuntu"
  2. Once the Live session has finished booting, open a terminal
  3. List the partitions on your notebook using fdisk:
    sudo fdisk -l
    You should see something like this:
    Device             Start        End   Sectors   Size Type
    /dev/nvme0n1p1      2048    2000895   1998848   976M EFI System
    /dev/nvme0n1p2   2000896  936214527 934213632 445.5G Linux filesystem
    /dev/nvme0n1p3 936214528 1000214527  64000000  30.5G Linux swap
    Note: Your machine might show device names like /dev/sda1, /dev/sda2, and so on.
  4. Identify the device that is of type EFI System. This is where your computer boots from.
  5. Mount the EFI System partition to /mnt so that you can access it:
    sudo mount /dev/nvme0n1p1 /mnt
    Note: Be sure to replace /dev/nmve0n1p1 with the proper device name for your computer's EFI System partition.
  6. Switch to the super user:
    sudo su
  7. Change to the /boot/efi/EFI/ubuntu directory on the EFI partition:
    cd /mnt/boot/efi/EFI/ubuntu
  8. List the contents of the directory using ll. You should see something like this:
    drwx------ 3 root root    4096  1月  6 14:39 ./
    drwx------ 4 root root    4096  7月  2  2019 ../
    -rwx------ 1 root root     108 10月  2 11:38 BOOTX64.CSV*
    drwx------ 2 root root    4096  1月 20 00:20 fw/
    -rwx------ 1 root root   60602  6月 19  2020 fwupdx64.efi*
    -rwx------ 1 root root     117 10月  2 11:38 grub.cfg*
    -rwx------ 1 root root 1681280 10月  2 11:38 grubx64.efi*
    -rwx------ 1 root root 1277024 10月  2 11:38 mmx64.efi*
    -rwx------ 1 root root 1341560 10月  2 11:38 shimx64.efi*
  9. Identify and copy an .efi file.
    • Do you have an mmx64.efi file in the list? Copy it to /boot/efi/EFI/BOOT:
    cp mmx64.efi /mnt/boot/efi/EFI/BOOT/mmx64.efi
    • If you do not have an mmx64.efi file but you do have grubx64.efi, copy that to /boot/efi/EFI/BOOT with the name mmx64.efi:
    cp grubx64.efi /mnt/boot/efi/EFI/BOOT/mmx64.efi
  10. Reboot the machine, remembering to remove the Live USB / DVD so that you boot from the hard drive.
This should resolve the issue.
