sudo apt update
Can anyone help resolve this?
ERROR:
Fatal error: E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/b
in/test -w /var/lib/command-not-found/ -a -e /usr/lib/cnf-update-db; then /usr/lib/cn
f-update-db > /dev/null; fi'
E: Sub-process returned an error code
File exists:
desktop:/usr/lib$ ls cnf-update-db
cnf-update-db
File contents:
#!/usr/bin/python3
import glob import logging import os import sys
from CommandNotFound.db.creator import DbCreator from CommandNotFound import CommandNotFound
if name == "main": if "--debug" in sys.argv[1:]: logging.basicConfig(level=logging.DEBUG) elif "--verbose" in sys.argv[1:]: logging.basicConfig(level=logging.INFO)
db = CommandNotFound.dbpath
if not os.access(os.path.dirname(db), os.W_OK):
    print("datbase directory %s not writable" % db)
    sys.exit(0)
command_files = glob.glob("/var/lib/apt/lists/*Commands-*")
if len(command_files) > 0:
    col = DbCreator(command_files)
    col.create(db)
muru
  • 207,228
