-1
when installing hplip plugin form the terminal i get this output :
HP Linux Imaging and Printing System (ver. 3.20.11)
Plugin Download and Install Utility ver. 2.1
Copyright (c) 2001-18 HP Development Company, LP This software comes with ABSOLUTELY NO WARRANTY. This is free software, and you are welcome to distribute it under certain conditions. See COPYING file for more details.
warning: It is not recommended to run 'hp-plugin' in a root mode.
HP Linux Imaging and Printing System (ver. 3.20.11) Plugin Download and Install Utility ver. 2.1
(Note: Defaults for each question are maked with a '*'. Press <enter> to accept the default.)
| PLUG-IN INSTALLATION FOR HPLIP 3.20.11 |
Option Description
d Download plug-in from HP (recommended)
p Specify a path to the plug-in (advanced)
q Quit hp-plugin (skip installation)
Enter option (d=download*, p=specify path, q=quit) ? d
| DOWNLOAD PLUGIN |
Checking for network connection... Downloading plug-in from: Downloading plug-in: [\ ] 0% Traceback (most recent call last): File "/usr/share/hplip/base/password.py", line 85, in get_distro_name os_name = platform.dist()[0] AttributeError: module 'platform' has no attribute 'dist'
During handling of the above exception, another exception occurred:
Traceback (most recent call last): File "/usr/bin/hp-plugin", line 363, in <module> status, plugin_path, error_str = pluginObj.download(plugin_path, plugin_download_callback) File "/usr/share/hplip/installer/pluginhandler.py", line 254, in download core = core_install.CoreInstall() File "/usr/share/hplip/installer/core_install.py", line 241, in init self.passwordObj = password.Password(ui_mode) File "/usr/share/hplip/base/password.py", line 118, in init self.readAuthType() # self.__authType File "/usr/share/hplip/base/password.py", line 141, in __readAuthType distro_name = get_distro_name().lower().replace(" ","") File "/usr/share/hplip/base/password.py", line 88, in get_distro_name os_name = distro.linux_distribution()[0] File "/usr/lib/python3/dist-packages/distro.py", line 122, in linux_distribution return _distro.linux_distribution(full_distribution_name) File "/usr/lib/python3/dist-packages/distro.py", line 677, in linux_distribution self.version(), File "/usr/lib/python3/dist-packages/distro.py", line 737, in version self.lsb_release_attr('release'), File "/usr/lib/python3/dist-packages/distro.py", line 899, in lsb_release_attr return self._lsb_release_info.get(attribute, '') File "/usr/lib/python3/dist-packages/distro.py", line 552, in __get ret = obj.dict[self._fname] = self._f(obj) File "/usr/lib/python3/dist-packages/distro.py", line 1012, in _lsb_release_info stdout = subprocess.check_output(cmd, stderr=devnull) File "/usr/lib/python3.8/subprocess.py", line 411, in check_output return run(*popenargs, stdout=PIPE, timeout=timeout, check=True, File "/usr/lib/python3.8/subprocess.py", line 512, in run raise CalledProcessError(retcode, process.args, subprocess.CalledProcessError: Command '('lsb_release', '-a')' returned non-zero exit status 1. Error in sys.excepthook: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 153, in apport_excepthook with os.fdopen(os.open(pr_filename, PermissionError: [Errno 13] Permission denied: '/var/crash/_usr_share_hplip_plugin.py.0.crash'
Original exception was: Traceback (most recent call last): File "/usr/share/hplip/base/password.py", line 85, in get_distro_name os_name = platform.dist()[0] AttributeError: module 'platform' has no attribute 'dist'
N0rbert
  • 103,263
Download your plugin version from openprinting and install with sh hplip-<version>-plugin.run
brian_p
  • 916
