I found instructions for the upgrade on Focal Release Notes, but when I follow them, they don't work. The steps I followed along with their outputs:
  • You can upgrade to Ubuntu 20.04 LTS from either Ubuntu 18.04 LTS or Ubuntu 19.10.
  • Ensure that you have all updates installed for your current version
    of Ubuntu before you upgrade.
Output of sudo apt update:
$ sudo apt update
Get:2 https //download.docker.com/linux/ubuntu eoan InRelease [43.0 kB]
Hit:1 https //packages.cloud.google.com/apt kubernetes-xenial InRelease
Hit:3 http //old-releases.ubuntu.com/ubuntu eoan InRelease
Hit:4 http //old-releases.ubuntu.com/ubuntu eoan-updates InRelease
Hit:5 http //old-releases.ubuntu.com/ubuntu eoan-backports InRelease
Hit:6 http //old-releases.ubuntu.com/ubuntu eoan-security InRelease
Fetched 43.0 kB in 3s (15.9 kB/s)
Reading package lists... Done
Building dependency tree
42 packages can be upgraded. Run 'apt list --upgradable' to see them.
  • Confirm that you also have a network connectivity to one of the official mirrors or to a locally accessible mirror as there are no offline upgrade options.
$ wget mirror.enzu.com.ubuntu
--2021-02-15 22:33:09--  http://mirror.enzu.com.ubuntu/
Resolving <MIRROR NAME> (<MIRROR NAME>)... 92.242.140.21
Connecting to <MIRROR NAME> (<MIRROR NAME>)|92.242.140.21|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/html]
Saving to: ‘index.html’
index.html [ <=> ] 894 --.-KB/s in 0s
2021-02-15 22:33:09 (9.06 MB/s) - ‘index.html’ saved [894]
  • Install update-manager-core if it is not already installed.
$ sudo apt install update-manager-core
update-manager-core is already the newest version (1:19.04.8).
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
  • Make sure the Prompt line in /etc/update-manager/release-upgrades is set to 'normal' if you are using 19.10, or 'lts' if you are using 18.04 LTS.
$ grep Prompt /etc/update-manager/release-upgrades
Prompt=normal
  • Launch the upgrade tool with the command sudo do-release-upgrade
$ sudo do-release-upgrade
Checking for a new Ubuntu release
Your Ubuntu release is not supported anymore.
For upgrade information, please visit:
http://www.ubuntu.com/releaseendoflife
Please install all available updates for your release before upgrading.
What have I done wrong? I edited the /etc/apt/sources.list to point it to the old-releases.ubuntu.com URLs and it appears that the apt update was successful. Why would the instructions say that I can do it from a particular version only to tell me that I can't do it because I am coming from that version?
Any help in explaining this to me would be most appreciated.
$ sudo apt full-upgrade
[sudo] password for dalex:
Calculating upgrade... Done
The following packages have been kept back:
  kubeadm kubectl kubelet
karel
  • 122,292
  • 133
  • 301
  • 332
dalex1
The following three packages can't be upgraded, and they are preventing the upgrade to 20.04: kubeadm kubectl kubelet. These packages are not essential to the operating system, and they can be reinstalled after the upgrade. Uninstall the three packages that can't be upgraded, and the upgrade can continue successfully.
sudo apt remove kubeadm kubectl kubelet
Here's another example of an error that occurred when trying to upgrade from Ubuntu 16.10 to Ubuntu 17.04.
click-apparmor : Depends: python3-apparmor-click (= 0.3.17) but 0.3.18 is installed
libubuntu-app-launch4 : Depends: ubuntu-app-launch (= 0.12+17.04.20170404.2-0ubuntu2) but 0.9+16.10.20160928-0ubuntu1 is installed
ubuntu-app-launch-tools : Depends: ubuntu-app-launch (= 0.12+17.04.20170404.2-0ubuntu2) but 0.9+16.10.20160928-0ubuntu1 is installed
url-dispatcher-tools : Depends: url-dispatcher (= 0.1+17.04.20170328-0ubuntu2) but 0.1+16.10.20160816.1-0ubuntu1 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or
specify a solution).
As you can see from the error message three packages that have 16.10 in their names are preventing similar packages that have 17.04 in their names from being installed. To solve this error uninstall the three packages in the above error message that have 16.10 in their names.
karel
  • 122,292
  • 133
  • 301
  • 332
