I need to upgrade the SSD in my home-server, from a 128GB to a 512GB. I also want to re-install the system instead of cloning, so that I can start from scratch.
I purchased the new SSD and an external USB3 case for it.
The process I had in mind was to save the data I need to save, remove the 128G SSD and replacing it with the 512G (only one slot in computer). Then boot with a USB flash drive and reinstall Xubuntu to the new hard drive.
But I thought maybe I can connect the new drive (with the USB case) to the computer and install everything there - then once I verify the installation works I can perform the actual switch of SSD inside the computer.
Which one of the two methods would you recommend and why? Or would you do differently altogether?
PS - not sure if it has any impact but the computer is a Dell OptiPlex 3070 Micro with UEFI and secure boot. Does this change anything?
thank you for any input.
