I want to install ns3.33 simulator on my ubuntu 20.04.2LTS and when I run the command:
apt-get install python-pygraphviz python-kiwi python-pygoocanvas libgoocanvas-dev ipython
I have these errors:
Package ipython is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source
E: Unable to locate package python-pygraphviz E: Unable to locate package python-kiwi E: Unable to locate package python-pygoocanvas E: Unable to locate package libgoocanvas-dev E: Package 'ipython' has no installation candidate
I have tried these commands, but the same problem:
sudo apt update sudo apt install python-pip python3-pip
sudo -H pip install ipython sudo -H pip3 install ipython
How to solve this ?
Sara
  • 23
If you install it from the GitHub it should work with 20.04.
Go to https://github.com/ipython/ipython/releases and download the Source Code (tar.gz) file.
Extract the contents:
tar zxvf ipython-7.18.1.tar.gz
Enter the newly created directory:
cd ipython-7.18.1/
Then use pip3 to install it:
pip3 install .
Don't forget to add the . at the end of the command meaning to install from here.
Hope this helps!
Terrance
  • 43,712
