I had an Ubuntu update days ago and I wasn't able to login my computer because of that, so I wrongly deleted in the kernel the version of the update, but I was able to continue working.
The problem now is that each time I use the apt-get command, it finishes with these lines (for example, trying to install ruby):
Reading package lists... Done
Building dependency tree
ruby is already the newest version (1:2.5.1).
The following packages were automatically installed and are no longer required:
command-not-found-data gcc-5-base gir1.2-gst-plugins-base-1.0
gir1.2-gstreamer-1.0 gir1.2-rb-3.0 gir1.2-totem-1.0 gir1.2-totemplparser-1.0
gyp libdmapsharing-3.0-2 libgpod-common libgpod4 libgsoap-2.8.60
libhttp-parser2.7.1 libjs-async libjs-inherits libjs-node-uuid libnetplan0
libsgutils2-2 libssl1.0-dev libuv1 libuv1-dev libvncserver1 libxatracker2
libxnvctrl0 libxvmc1 linux-hwe-5.4-headers-5.4.0-42
linux-hwe-5.4-headers-5.4.0-56 linux-hwe-5.4-headers-5.4.0-58
linux-hwe-5.4-headers-5.4.0-59 linux-hwe-5.4-headers-5.4.0-62 node-abbrev
node-ansi node-ansi-color-table node-archy node-async node-balanced-match
node-block-stream node-brace-expansion node-combined-stream node-concat-map
node-cookie-jar node-delayed-stream node-forever-agent node-form-data
node-fs.realpath node-fstream node-fstream-ignore node-github-url-from-git
node-glob node-graceful-fs node-gyp node-hosted-git-info node-inflight
node-inherits node-ini node-isexe node-json-stringify-safe node-lockfile
node-lru-cache node-mime node-minimatch node-mkdirp node-mute-stream
node-node-uuid node-nopt node-npmlog node-once node-osenv
node-path-is-absolute node-pseudomap node-qs node-read node-request
node-retry node-rimraf node-semver node-sha node-slide node-spdx-correct
node-spdx-expression-parse node-spdx-license-ids node-tar node-tunnel-agent
node-underscore node-validate-npm-package-license node-which node-wrappy
node-yallist nodejs-doc pkg-config
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up linux-image-5.4.0-65-generic (5.4.0-65.73~18.04.1) ...
Setting up linux-headers-5.4.0-65-generic (5.4.0-65.73~18.04.1) ...
/etc/kernel/header_postinst.d/dkms:
* dkms: running auto installation service for kernel 5.4.0-65-generic
Error! Could not locate dkms.conf file.
File: does not exist.
...fail!
run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 4
dpkg: error processing package linux-headers-5.4.0-65-generic (--configure):
installed linux-headers-5.4.0-65-generic package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of linux-headers-generic-hwe-18.04:
linux-headers-generic-hwe-18.04 depends on linux-headers-5.4.0-65-generic; however:
Package linux-headers-5.4.0-65-generic is not configured yet.
dpkg: error processing package linux-headers-generic-hwe-18.04 (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-generic-hwe-18.04:
linux-generic-hwe-18.04 depends on linux-headers-generic-hwe-18.04 (= 5.4.0.65.73~18.04.60); however:
Package linux-headers-generic-hwe-18.04 is not configured yet.
dpkg: error processing package linux-generic-hwe-18.04 (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
Processing triggers for linux-image-5.4.0-65-generic (5.4.0-65.73~18.04.1) ...
/etc/kernel/postinst.d/dkms:
- dkms: running auto installation service for kernel 5.4.0-65-generic
...fail!
run-parts: /etc/kernel/postinst.d/dkms exited with return code 4
dpkg: error processing package linux-image-5.4.0-65-generic (--configure):
installed linux-image-5.4.0-65-generic package post-installation script subprocess returned error exit status 1
No apport report written because MaxReports is reached already
How could I fix it? (Maybe it's a dumb thing, but I'm not a pro using Ubuntu, so sorry if in advance).
EDIT:
After running sudo apt autoremove:
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
...fail!
...fail!
After running sudo apt purge
...fail!
...fail!
After running sudo apt-get -f install
...fail!
...fail!
After running sudo dpkg-reconfigure linux-image-5.4.0-65-generic
/usr/sbin/dpkg-reconfigure: linux-image-5.4.0-65-generic is broken or not fully installed
After running sudo dpkg-reconfigure --force linux-image-5.4.0-65-generic there is no output
