I've been running into this issue every time I run a repo init -u https://source.codeaurora.org/quic/le/le/manifest.git -b [branch] -m [manifest] command.
>> repo 1.12.16
stderr:
>> gpg: Signature made Thu 01 May 2014 01:34:18 PM PDT using RSA key ID 692B382C
>> gpg: Can't check signature: public key not found
>> error: could not verify the tag 'v1.12.16'
fatal: cloning the git-repo repository failed, will remove '.repo/repo'
Then I installed the repo package via sudo apt-get install repo which seems to install the repo in /usr/bin dir so upon running $/usr/bin/repo init -u https://source.codeaurora.org/quic/le/le/manifest.git -b [branch] -m [manifest] , I now see:
repo: error: "git" failed with exit status 1
stderr:
>> gpg: Signature made Thu 22 June 2012 01:14:15 PM PDT using RSA key ID 692B382C
I tried this approach to no avail.
