When I run sudo apt-get upgrade
I get this:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages will be upgraded:
  base-files bluez-firmware ca-certificates device-tree-compiler file
  firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree
  firmware-realtek gstreamer1.0-plugins-bad iproute2 libgnutls30
  libgstreamer-plugins-bad1.0-0 libldap-2.4-2 libldap-common libmagic-mgc
  libmagic1 libpam-systemd libpq5 libraspberrypi-bin libraspberrypi-dev
  libraspberrypi-doc libraspberrypi0 libsnmp-base libsnmp30 libsystemd0
  libudev1 libvlc-bin libvlc5 libvlccore9 lxplug-bluetooth lxplug-volumepulse
  node-ini node-y18n nodered pcmanfm python-rpi.gpio python3-rpi.gpio
  raspberrypi-bootloader raspberrypi-kernel raspberrypi-sys-mods raspi-config
  rc-gui rpi-chromium-mods rpi-eeprom rpi.gpio-common sudo systemd
  systemd-sysv thonny tzdata udev unzip vlc vlc-bin vlc-data vlc-l10n
  vlc-plugin-base vlc-plugin-notify vlc-plugin-qt vlc-plugin-samba
  vlc-plugin-skins2 vlc-plugin-video-output vlc-plugin-video-splitter
  vlc-plugin-visualization xserver-common xserver-xorg-core
68 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/174 MB of archives.
After this operation, 6,028 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
dpkg-deb (subprocess): decompressing archive member: lzma error: compressed data is corrupt
dpkg-deb: error: <decompress> subprocess returned error exit status 2
dpkg-deb (subprocess): cannot copy archive member from '/var/cache/apt/archives/raspberrypi-kernel_1.20210201-1_armhf.deb' to decompressor pipe: failed to write (Broken pipe)
dpkg-deb (subprocess): cannot copy archive member from '/var/cache/apt/archives/raspberrypi-bootloader_1.20210201-1_armhf.deb' to decompressor pipe: failed to write (Broken pipe)
Reading changelogs... Done
debconf: Perl may be unconfigured (Can't load '/usr/lib/arm-linux-gnueabihf/perl/5.28/auto/Hash/Util/Util.so' for module Hash::Util: /usr/lib/arm-linux-gnueabihf/perl/5.28/auto/Hash/Util/Util.so: invalid ELF header at /usr/share/perl/5.28/XSLoader.pm line 93.
 at /usr/lib/arm-linux-gnueabihf/perl/5.28/Hash/Util.pm line 47.
BEGIN failed--compilation aborted at /usr/lib/arm-linux-gnueabihf/perl/5.28/Hash/Util.pm line 48.
Compilation failed in require at /usr/share/perl/5.28/fields.pm line 124.
Compilation failed in require at /usr/share/perl5/Debconf/Log.pm line 10.
Compilation failed in require at (eval 1) line 4.
BEGIN failed--compilation aborted at (eval 1) line 4.
) -- aborting
dpkg: warning: files list file for package 'linux-base' missing; assuming package has no files currently installed
dpkg: warning: files list file for package 'linux-libc-dev:armhf' missing; assuming package has no files currently installed
dpkg: unrecoverable fatal error, aborting:
 files list file for package 'libusbmuxd4:armhf' is missing final newline
E: Sub-process /usr/bin/dpkg returned an error code (2)
I already tried this:
 sudo dpkg --configure -a
 sudo apt-get -f install
 sudo apt-get clean
 sudo apt-get update && sudo apt-get upgrade
Thanks in advance
