What would be the command to allow a specific application to view other drives, like Clementine ?
I can't add content to my library from other drives.
Ubuntu 20.10 groovy (x86-64)
With Cinnamon 4.6.7
kernel: 5.8.0-43-generic
With Cinnamon 4.6.7
Just give the required permission
sudo snap connect clementine:removable-media
sudo snap connect clementine:desktop-legacy
I've entered a terminal as root** sudo su then:
1. Purge the snap version installed of the clementine package:
snap remove clementine --purge
2. Use apt install instead :
apt install clementine
I've also seen this issue in other/later Ubuntu Flavors's releases using gnome-software as a base like it seems to me, that installing another one (like synaptic or snaps) could cause this. Maybe there's a general way to do so that the rights of installed package are set too for a freshly installed software manager.
By the way, I always use an Ubuntu flavors's releases as a base installation and never have trouble with gnome-software installed packages (mostly apt install with terminal). I did not use Snaps on my other tests.
After that Clementine could access all my disks like it should.
