On https://cloud-images.ubuntu.com/groovy/current/ there is (among many others) both a groovy-server-cloudimg-amd64-disk-kvm.img and a groovy-server-cloudimg-amd64.img. What's the difference?
Asked
Active
Viewed 3,894 times
You can look at the .manifest files available on the same page. You will see that the difference is the kernel being used. The disk-kvm.img variant has linux-image-kvm 5.8.0.1018.20 while the other image has linux-image-5.8.0-43-generic.
The former is a reduced kernel for use in virtual environments, it might miss some modules/configs but is a bit lighter.
The second is the generic kernel that works everywhere. You'd use those images e.g. to deploy a new bare-metal system with them or in any other place where the linux-kvm represents a limitation you do not want.
If in doubt and you only have to select only one, then the non-kvm image is the one that should work everywhere.
Here you can read more about Ubuntu kernel variants
Christian Ehrhardt
- 2,195
- 16
- 22
