I am trying to create a bootable USB startup disk in 20.04
According to instructions, I should use "Startup Disk Creator". But this application does not appear to be installed on my machine. So to Ubuntu Software Centre, but a search there only give the message application not found.
Where is it then?
joel
  • 42
If you are comfortable using the command line, you can install it as follows:
sudo apt update
sudo apt install usb-creator-gtk
Note:
On my system, I have two "software centers" installed.
  1. Software
  2. Ubuntu Software
When I search for "Startup Disk Creator" in either of these, I do get a listing for this application. I am also able to search using "usb-creator-gtk", and I get a result.
Try searching for "usb-creator-gtk". If you don't get a result, there may be another issue on your system.
However, executing the (apt) commands above will show you if there is another underlying error.
Enterprise
  • 12,792
You ask about the specific software, but I hope there is enough room here to point out that you do not necessarily need that software.
I have created my live USB installer with the terminal's copy utility (the cp command).
I have taken that guidance from here:
https://wiki.archlinux.org/index.php/USB_flash_installation_medium#Using_basic_command_line_utilities
(This guide contains guidance for other CLI utility procedures too, like cat, dd, and tee. I picked cp because it seemed the least complicated.)
An excerpt of the above would amount to the following:
  • Be aware that this procedure will destroy all data on the USB stick that it previously contained.
  • After you have plugged in the USB stick, use the lsblk command to determine its identifier (e.g. sdx or something like that — replace the here symbolically used x to the actual letter your system indicates).
  • Make sure it's not mounted.
    • If the system has automounted it for you, then unmount it with the umount command.
  • Use the cp path/to/ubuntu-desktop-image.iso /dev/sdx command to copy the image to the USB stick.
    • Make sure that you specify the entire device and not a partition on it:
      • That's done by ensuring that the identifier does not end with a number:
        • sdx1: not good
        • sdx: good
In case the resulting USB installer does not seem to work, it's worth attempting the procedure at least once more, before trying with something else.
Levente
  • 4,607
