Hey stackexchange community, I would like to run selenium for python, with firefox geckodriver in google recolab. I've found a post regarding this topic recently in which there's an answer by @DebanjanB from a while ago: https://stackoverflow.com/a/57553986/15163882 . Sadly the provided solution, no longer works and I couldn't figure out how to fix it.
this is the code from the stackoverflow answer, that's supposed to download and run geckodriver;
# install firefox, geckodriver, and selenium
!apt-get update
!pip install selenium
!apt install firefox-geckodriver
!cp /usr/lib/geckodriver /usr/bin
!cp /usr/lib/firefox /usr/bin
from selenium import webdriver
binary = '/usr/bin/firefox' options = webdriver.FirefoxOptions() options.binary = binary options.add_argument('start-maximized') options.add_argument('--headless') browser = webdriver.Firefox(firefox_options=options, executable_path='/usr/bin/geckodriver') browser.get('http://google.com/')
!cp /usr/lib/geckodriver /usr/bin results in error, there's no such file, the geckodriver is stored in /usr/bin/geckodriver. !cp /usr/lib/firefox /usr/bin doesn't work too, /usr/lib/firefox is a directory, not a file. Overall, the code fails with the exception: Process unexpectedly closed with status signal
here's the full error output:
/usr/local/lib/python3.6/dist-packages/selenium/webdriver/firefox/webdriver.py in __init__(self, firefox_profile, firefox_binary, timeout, capabilities, proxy, executable_path, options, service_log_path, firefox_options, service_args, desired_capabilities, log_path, keep_alive)
    172                 command_executor=executor,
    173                 desired_capabilities=capabilities,
--> 174                 keep_alive=True)
    175
    176         # Selenium remote
/usr/local/lib/python3.6/dist-packages/selenium/webdriver/remote/webdriver.py in init(self, command_executor, desired_capabilities, browser_profile, proxy, keep_alive, file_detector, options) 155 warnings.warn("Please use FirefoxOptions to set browser profile", 156 DeprecationWarning, stacklevel=2) --> 157 self.start_session(capabilities, browser_profile) 158 self._switch_to = SwitchTo(self) 159 self._mobile = Mobile(self)
/usr/local/lib/python3.6/dist-packages/selenium/webdriver/remote/webdriver.py in start_session(self, capabilities, browser_profile) 250 parameters = {"capabilities": w3c_caps, 251 "desiredCapabilities": capabilities} --> 252 response = self.execute(Command.NEW_SESSION, parameters) 253 if 'sessionId' not in response: 254 response = response['value']
/usr/local/lib/python3.6/dist-packages/selenium/webdriver/remote/webdriver.py in execute(self, driver_command, params) 319 response = self.command_executor.execute(driver_command, params) 320 if response: --> 321 self.error_handler.check_response(response) 322 response['value'] = self._unwrap_value( 323 response.get('value', None))
/usr/local/lib/python3.6/dist-packages/selenium/webdriver/remote/errorhandler.py in check_response(self, response) 240 alert_text = value['alert'].get('text') 241 raise exception_class(message, screen, stacktrace, alert_text) --> 242 raise exception_class(message, screen, stacktrace) 243 244 def _value_or_default(self, obj, key, default):
WebDriverException: Message: Process unexpectedly closed with status signal
Update #1
Here's my best try, it puts everything in all the paths needed:
import sys,os
from os import system as o
def sudo_cmd(cmd):o('echo %s|sudo -S %s' % ('12345678', cmd)) sudo_cmd('apt-get update')
sudo_cmd('apt install firefox-geckodriver') sudo_cmd('cp /usr/lib/geckodriver /usr/bin') sys.path.insert(0,'/usr/lib/geckodriver')
options = webdriver.FirefoxOptions() options.headless = True options.add_argument('--no-sandbox') driver = webdriver.Firefox(options=options, executable_path='geckodriver') driver.get('https://www.google.com/')
But I still get the same Error.
Also I noticed that the geckodriver.log file outputs src/tcmalloc.cc:283] Attempt to free invalid pointer 0x7fa48e915160 Redirecting call to abort() to mozalloc_abort before the setup code errors out.
The remote server is running on Linux-4.19.112+-x86_64-with-Ubuntu-18.04-bionic. If you have a google account, try it yourself here for free: https://colab.research.google.com/drive/#create=true#forceEdit=true
I would be happy if anyone could help me!
Mika C.
