When I turn my airbuds on and connect them to my laptop they keep turning on and off without even asking me and sometimes Wifi does this too.
In Settings it's written that Wifi and Bluetooth can automatically turn off to save power, but I don't want to save power. I can't find any way to to turn this annoying option off.
Please help me out, I just want it to stop automatically turning off Wifi and Bluetooth. Thank you.
Zanna
  • 72,312
One thing I have tried is leaving the Settings application open under Bluetooth. Does not "fix" the issue, but it does helps make the disconnect much less bad!
Zanna
  • 72,312
Try this, it worked for me:
From: bluetooth keeps turning off in 19.04 after physically and manually turning off bluetooth device, any fix to this?
sudo rmmod btusb
sudo modprobe btusb
Zanna
  • 72,312
nirala
  • 214
The bluetooth and wifi may turn off automatically in Ubuntu to save power. This option can be disabled using
xset -dpms
Add this command to to startup applications to disable power saving option by default. Found this solution from following links:
  1. https://ubuntuforums.org/showthread.php?t=2289662&p=13334149#post13334149
  2. https://ubuntuforums.org/showthread.php?t=1483345&page=2&p=10307995&viewfull=1#post10307995
hkbharath
  • 183
