every time I try to install mysql-workbentch on terminal using the sudo apt install mysql-workbentch command, the following error occurs:
$ sudo apt install mysql-workbench-community
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: mysql-workbench-community : Depends: libc6 (>= 2.29) but 2.28-10 is to be installed Depends: libmysqlclient21 (>= 8.0.11) but it is not installable Depends: libstdc++6 (>= 9) but 8.3.0-6 is to be installed Depends: libzip5 (>= 0.10) but it is not installable E: Unable to correct problems, you have held broken packages.
I am a little new to the ubunto and this problem has already taken a lot of my time, and many unsuccessful attempts. Whoever can help me, I will be forever grateful.
