I'm trying to install ns3 and, before that, I need to run the command below:
sudo apt install gir1.2-goocanvas-2.0 python-gi python-gi-cairo python-pygraphviz python3-gi python3-gi-cairo python3-pygraphviz gir1.2-gtk-3.0 ipython ipython3
After running this command, I get this error:
 ipython : Depends: python-ipython (= 5.5.0-1) but it is not going to be installed
 python-gi : Depends: python2 (< 2.8) but it is not going to be installed
             Depends: python2 (>= 2.7~) but it is not going to be installed
             Depends: python2:any (< 2.8)
             Depends: python2:any (>= 2.7~)
 python-gi-cairo : Depends: python-cairo (>= 1.11.1) but it is not going to be installed
What should I do to solve this problem?
If by ns3 you mean the ns-3 network simulator, there's some guidance on installing it on Ubuntu on their wiki.
It looks like a long list of pre-requisites, but they publish the exact commands you need.
https://www.nsnam.org/wiki/Installation#Ubuntu.2FDebian.2FMint
But please edit your question and indicate what version of Ubuntu you are using, because what you need to do may vary.
Also, the website mentions python (which in older releases means python2) and python3. Their software is in transition.
mondotofu
  • 817
First, make sure you run the command
sudo apt update
Then, run the command
If it gives the same error, then install python-pip and python3-pip using
sudo apt install python-pip python3-pip
Once done, install ipython via pip
sudo -H pip install ipython
sudo -H pip3 install ipython
Finally, run
