I have an issue with the wired connection in Ubuntu 20.04. When I restart the wired connection, the internet is connecting for 10 seconds and after that internet disconnected. It happens after connecting to another ethernet. I've tested in Windows on the same device and the wired connection work perfectly.
ifconfig:
br-01eaafad0ac5: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.18.0.1 netmask 255.255.0.0 broadcast 172.18.255.255
ether 02:42:c2:c2:d7:40 txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
br-8af8a389b013: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.49.1 netmask 255.255.255.0 broadcast 192.168.49.255
ether 02:42:a3:bb:fd:20 txqueuelen 0 (Ethernet)
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:13:f0:9d:0a txqueuelen 0 (Ethernet)
enp2s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.17.0.125 netmask 255.255.255.0 broadcast 172.17.0.255
inet6 fe80::bdbd:d4d3:27b0:da2b prefixlen 64 scopeid 0x20<link>
ether 8c:0f:6f:72:74:2e txqueuelen 1000 (Ethernet)
RX packets 72 bytes 15513 (15.5 KB)
RX errors 0 dropped 4 overruns 0 frame 0
TX packets 304 bytes 25513 (25.5 KB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 1613 bytes 148550 (148.5 KB)
TX packets 1613 bytes 148550 (148.5 KB)
wlp1s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 40:9f:38:0c:4d:97 txqueuelen 1000 (Ethernet)
wlx1062eb320a88: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.43.3 netmask 255.255.255.0 broadcast 192.168.43.255
inet6 fe80::d8c2:1da0:643e:f5cf prefixlen 64 scopeid 0x20<link>
ether 10:62:eb:32:0a:88 txqueuelen 1000 (Ethernet)
RX packets 4026 bytes 7045370 (7.0 MB)
RX errors 0 dropped 265 overruns 0 frame 0
TX packets 2740 bytes 1329710 (1.3 MB)
sudo lshw -C network:
*-network
description: Wireless interface
product: RTL8723BE PCIe Wireless Network Adapter
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: wlp1s0
version: 00
serial: 40:9f:38:0c:4d:97
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rtl8723be driverversion=5.8.0-48-generic firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11
resources: irq:17 ioport:e000(size=256) memory:df100000-df103fff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0
version: 15
serial: 8c:0f:6f:72:74:2e
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.8.0-48-generic duplex=full firmware=rtl8168h-2_0.0.2 02/26/15 ip=172.17.0.125 latency=0 link=yes multicast=yes port=MII speed=1Gbit/s
resources: irq:19 ioport:d000(size=256) memory:df004000-df004fff memory:df000000-df003fff
*-network
physical id: 1
bus info: usb@1:6
logical name: wlx1062eb320a88
serial: 10:62:eb:32:0a:88
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=r8188eu driverversion=5.8.0-48-generic ip=192.168.43.3 multicast=yes wireless=IEEE 802.11bgn
dmesg | grep e1000e: Nothing
dmesg | grep r81
[ 0.026270] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u524288
[ 0.026275] pcpu-alloc: s192512 r8192 d28672 u524288 alloc=1*2097152
[ 0.676015] libphy: r8169: probed
[ 0.676174] r8169 0000:02:00.0 eth0: RTL8168h/8111h, 8c:0f:6f:72:74:2e, XID 541, IRQ 126
[ 0.676175] r8169 0000:02:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 0.677083] r8169 0000:02:00.0 enp2s0: renamed from eth0
[ 3.588250] r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.709693] usbcore: registered new interface driver r8188eu
[ 3.986279] r8188eu 1-6:1.0 wlx1062eb320a88: renamed from wlan0
[ 6.410031] Generic FE-GE Realtek PHY r8169-200:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-200:00, irq=IGNORE)
[ 6.609967] r8169 0000:02:00.0 enp2s0: Link is Down
[ 319.190371] r8169 0000:02:00.0 enp2s0: Link is Up - 1Gbps/Full - flow control off
[27285.099624] r8169 0000:02:00.0 enp2s0: Link is Down
[27292.060262] Generic FE-GE Realtek PHY r8169-200:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-200:00, irq=IGNORE)
[27292.244453] r8169 0000:02:00.0 enp2s0: Link is Down
[27296.397106] r8169 0000:02:00.0 enp2s0: Link is Up - 1Gbps/Full - flow control off
[29075.912170] r8188eu 1-6:1.0 wlx1062eb320a88: renamed from wlan0
[59818.035387] r8169 0000:02:00.0 enp2s0: Link is Down
[59821.142964] Generic FE-GE Realtek PHY r8169-200:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-200:00, irq=IGNORE)
[59821.339009] r8169 0000:02:00.0 enp2s0: Link is Down
[59825.437233] r8169 0000:02:00.0 enp2s0: Link is Up - 1Gbps/Full - flow control off
lsmod | grep r81:
r8188eu 430080 0
lib80211 16384 1 r8188eu
cfg80211 778240 3 rtlwifi,mac80211,r8188eu
r8169 77824 0
apt-cache policy r8168-dkms:
r8168-dkms:
Installed: (none)
Candidate: 8.048.00-1ubuntu0.20.04.1
Version table:
8.048.00-1ubuntu0.20.04.1 500
500 http://ir.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
500 http://ir.archive.ubuntu.com/ubuntu focal-updates/universe i386 Packages
8.048.00-1 500
500 http://ir.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
500 http://ir.archive.ubuntu.com/ubuntu focal/universe i386 Packages
