I recently updated to windows 10.
When I boot to windows from grub I get the error: "Windows Failed to Start A Recent Hardware or Software Change Might Be The Cause."
Changing the name in /boot/grub/grib.config to "windows 10" from "windows 7" didn't fix it.
The only way to boot to windows is to switch to bios, and manually boot to the drive that windows is on. This is inconvenient and I would like to know how to update grub to reflect the change to windows 10.
I tried Ubuntu Boot repair, but it again set my boot option to "windows 7."
I'm not sure which logs to look at.
Ben Alan
  • 119
Boot to Ubuntu and mount the Windows drive (if you're using UEFI, mount the EFI partition too as root.)
Use the command:
sudo os-prober
and try updating the GRUB config using the command:
sudo update-grub
It will automatically detect the changes and you can try booting again.
Also, don't update GRUB manually from grub.cfg. There could be unintended side effects. Next time if you want to edit the config, use:
sudo apt install grub-customizer
GRUB Customizer can help rename, add, delete and edit your entries. It's a good tool and you can use it on Ubuntu.
Amint
  • 444
