I run apt autoremove apt upgrade apt upgrade and get:
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
then run do-release-upgrade and get
Checking for a new Ubuntu release
Get:1 Upgrade tool signature [1,554 B]
Get:2 Upgrade tool [1,341 kB]
Fetched 1,343 kB in 0s (0 B/s)
authenticate 'focal.tar.gz' against 'focal.tar.gz.gpg'
extracting 'focal.tar.gz'
Reading cache
Checking package manager Reading package lists... Done Building dependency tree
Reading state information... Done Hit http://us.archive.ubuntu.com/ubuntu bionic InRelease
Hit http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease
Hit http://us.archive.ubuntu.com/ubuntu bionic-security InRelease
Fetched 0 B in 0s (0 B/s)
Restoring original system state
Aborting Reading package lists... Done
a look in main log says this:
2021-02-05 11:19:03,793 INFO Using config files '['./DistUpgrade.cfg.bionic']'
2021-02-05 11:19:03,793 INFO uname information: 'Linux chas-pc 4.15.0-135-generic #139-Ubuntu SMP Mon Jan 18 17:38:24 UTC 2021 x86_64'
2021-02-05 11:19:04,128 INFO apt version: '1.6.12ubuntu0.2'
2021-02-05 11:19:04,129 INFO python version: '3.6.9 (default, Oct  8 2020, 12:12:24)
[GCC 8.4.0]'
2021-02-05 11:19:04,131 INFO release-upgrader version '20.04.29' started
2021-02-05 11:19:04,140 INFO locale: 'en_US' 'UTF-8'
2021-02-05 11:19:04,182 INFO screen could not be run
2021-02-05 11:19:04,211 DEBUG Using 'DistUpgradeViewText' view
2021-02-05 11:19:04,252 DEBUG enable dpkg --force-overwrite
2021-02-05 11:19:04,284 DEBUG creating statefile: '/var/log/dist-upgrade/apt-clone_system_state.tar.gz'
2021-02-05 11:19:08,353 DEBUG lsb-release: 'bionic'
2021-02-05 11:19:08,353 DEBUG _pythonSymlinkCheck run
2021-02-05 11:19:08,354 DEBUG openCache()
2021-02-05 11:19:08,354 DEBUG quirks: running PreCacheOpen
2021-02-05 11:19:08,354 DEBUG running Quirks.PreCacheOpen
2021-02-05 11:19:09,476 DEBUG Comparing 4.15.0-134 with
2021-02-05 11:19:09,476 DEBUG Comparing 4.15.0-135 with 4.15.0-134
2021-02-05 11:19:09,830 DEBUG /openCache(), new cache size 101938
2021-02-05 11:19:09,830 DEBUG need_server_mode(): run in 'desktop' mode, (because of pkg 'ubuntu-desktop')
2021-02-05 11:19:09,831 DEBUG checkViewDepends()
2021-02-05 11:19:09,832 DEBUG running doUpdate() (showErrors=False)
2021-02-05 11:19:10,951 DEBUG openCache()
2021-02-05 11:19:12,112 DEBUG Comparing 4.15.0-134 with
2021-02-05 11:19:12,112 DEBUG Comparing 4.15.0-135 with 4.15.0-134
2021-02-05 11:19:12,471 DEBUG /openCache(), new cache size 101938
2021-02-05 11:19:12,471 DEBUG doPostInitialUpdate
2021-02-05 11:19:12,472 DEBUG quirks: running focalPostInitialUpdate
2021-02-05 11:19:12,472 DEBUG running Quirks.focalPostInitialUpdate
2021-02-05 11:21:13,735 DEBUG abort called
2021-02-05 11:21:13,735 DEBUG openCache()
2021-02-05 11:21:14,862 DEBUG Comparing 4.15.0-134 with
2021-02-05 11:21:14,863 DEBUG Comparing 4.15.0-135 with 4.15.0-134
2021-02-05 11:21:15,215 DEBUG /openCache(), new cache size 101938
Is obvious a problem here but I don't know it. What is it anyone?
Here is output of survice snapd status (output repeated many times untill I do control-c):
● snapd.service - Snap Daemon
   Loaded: loaded (/lib/systemd/system/snapd.service; enabled; vendor preset: en
   Active: failed (Result: exit-code) since Fri 2021-02-05 11:00:37 CST; 22h ago
  Process: 1414 ExecStart=/usr/lib/snapd/snapd (code=exited, status=1/FAILURE)
 Main PID: 1414 (code=exited, status=1/FAILURE)
Feb 05 11:00:37 chas-pc systemd[1]: snapd.service: Service hold-off time over, s Feb 05 11:00:37 chas-pc systemd[1]: snapd.service: Scheduled restart job, restar Feb 05 11:00:37 chas-pc systemd[1]: Stopped Snap Daemon. Feb 05 11:00:37 chas-pc systemd[1]: snapd.service: Start request repeated too qu Feb 05 11:00:37 chas-pc systemd[1]: snapd.service: Failed with result 'exit-code Feb 05 11:00:37 chas-pc systemd[1]: Failed to start Snap Daemon. Feb 05 11:00:37 chas-pc systemd[1]: snapd.service: Triggering OnFailure= depende lines 1-13/13 (END)
cedwin
  • 161
The secret to my being able to upgrade to 20.04.02 was the removal (purge) of snapd. My procedure was:
  1. Did a backup of the system and all files.
  2. In terminal mode: $ sudo apt-get purge snapd Type y and Enter to continue when asked. This removed snapd from my system.
  3. Clean up any remaining dependencies with $ sudo apt-get autoremove (type y and Return when asked if want to continue)
  4. Then proceed to upgrade Ubuntu by going to "Show Applications" to bring up "Software Updater," click on "Upgrade..." and the upgrade completed without problem. (See the transcripts above for how snapd was identified as the source of the upgrading problem.)
cedwin
  • 161
I tried removing snapd but it still doesn't work. Then I exited my screen session and run it in a normal console, then it worked.
