For some times now, my Dell XPS 13 7390 has been lagging in a very annoying way. Startup time has got longer, and the laptop is sometimes very unresponsive.
After some investigation, it came to suspect the SSD. At first, it looks healthy. smartctl says:
SMART overall-health self-assessment test result: PASSED
Error Information (NVMe Log 0x01, max 64 entries)
No Errors Logged
However, gnome-disk's benchmark gives strange results: just after the sluggish startup, running the benchmark gives me a mediocre read rate (<300MB/s) and huge access time (20-30 msec).
Then I noticed that if I run the benchmark a second time, just after the first one, results are back to normal with a read rate of ~500MB/s and access time of 0.1 msec! And then the system is responsive again. But the lagging comes again after a while, although running the benchmark again seems to fix it... :-/.
I tried with slightly older versions of the kernel (down to 5.8.0.34), and notice that:
- if
linux-module-extrasis not installed, the first benchmark I run after boot is ok; - if
linux-module-extrasis installed, I have the same strange behavior as described above.
So maybe one of the extra modules is messing with the SSD? And maybe the benchmark does something that puts it back in order?
Can anyone make sense of all this? Thanks in advance...
edit I first assumed that benchmark was doing some clean-up operation at the end that fixed the problem temporarily, but it does not always work. More probably, it is just the fact that I am doing nothing else than waiting for the benchmark to finish, allowing whatever causes the lag to cool down...
edit I just got a long period of lag, with no app running except for the software updater. iotop revealed that update-mime-database was consuming 99% of IO. The lag stopped once the update was over. This seems to be related to this issue. So background updates could be causing these seemingly random lags. Since the absence of extra-modules means no network, hence no background update, this is consistent...
