When I go to System -> Preferences -> About me, I am able to give all sorts of informations, like my name, my e-mail address, an avatar, et cætera.
What is it made for?
Braiam
  • 69,112
Agmenor
  • 16,394
If you change your login screen to list users instead of making you type in your username, it'll show the avatar you set next to your name. It'll also show your real name instead of your username if you set it in there. I think this real-name-versus-username thing also affects the Me Menu (at least, it affected the equivalent applet a few releases ago...). As ayan4m1 mentioned, you can change your password there, too. Finally, I think some of this data is auto-filled-in in your Evolution address book if you set it here.
maco
  • 16,132
It seems there are several ubuntu brainstorms on this subject. About Me is a simple way to store a bunch of common personal information. It is part of GNOME. Some people no doubt use it in hopes that if their laptop is lost, someone may use the information to contact them. I believe it also allows users to change their password, which is essential if they are not an administrator and do not have access to the Users and Groups control panel item. As far as I can tell, no applications have programmatic access to the information fields in About Me.
ayan4m1
  • 933
There was a plan to simplify the About Me window so that it would only be used by the Me Menu, but I don't know what happened to it.
Mock-up of simplified About Me window
They put it their for an LDAP server to use. Or that other one Active Directory used by the Bad Guys Obviously not the window it self but the data in the file.
