I want to have an encrypted external ssd for occasional backups. It seems like consumer products don't really support linux, so unless someone has a better suggestion I'm planning to format it myself and use software encryption, using LUKS with some filesystem inside.
  1. Does this make sense?
  2. Which filesystem should I choose?
  3. Any features I should watch out for when buying the ssd?
Relevant aspects to answer these questions are mainly:
  • Stability
  • Lifetime of the device
  • Checksums like in btrfs or zfs would be nice, but aren't a hard requirement
Thanks in advance for your suggestions!
Yes, it does
This depends on your needs. I use ext4 because I am used to it and also use it on my laptop's /home partition. I also do not care for non-linux interoperability (by the way if you use luks for encryption you probably do not care either).
This is off topic on this site and unfortunately something I can not answer. I tend to buy cheap external disks, but I also have always two active backups.
Bruni
  • 11,099
