I have to merge a lot of pdf files and I numbered them from 1 to 100 or more. I want to merge specific files.
Can I merge them doing something similar to this?
pdftk [1-20].pdf cat output out.pdf
Ram
  • 101
If I understand correctly, in your example you want to merge the first 20 pdf files, i.e. the files with names from 1.pdf to 20.pdf. You can do that using brace expansion, so the command you need to run is:
pdftk {1..20}.pdf cat output out.pdf
In essence, {1..20}.pdf is expanded by the shell to 1.pdf, 2.pdf, 3.pdf, ..., 20.pdf, so it's the same as running (the ellipses signify the intermediate files):
pdftk 1.pdf 2.pdf 3.pdf ... 20.pdf cat output out.pdf
