I'm on Ubuntu 20.04. After (trying) to purge everything Deepin-related on my system, every time I try and install something from the terminal it includes trying to get me to remove something called "deepin-anything-server".
Example:
The following additional packages will be installed:
clamav-base clamav-freshclam libclamav9 libtfm1
Suggested packages:
clamav-docs libclamunrar9
The following packages will be REMOVED:
The following NEW packages will be installed:
clamav clamav-base clamav-freshclam libclamav9 libtfm1
0 upgraded, 5 newly installed, 1 to remove and 0 not upgraded.
2 not fully installed or removed.
Need to get 0 B/1,135 kB of archives.
After this operation, 3,450 kB of additional disk space will be used.
Do you want to continue? [Y/n]
So I press y and it does its thing. But every single time this error comes up:
Preconfiguring packages ...
(Reading database ... 339973 files and directories currently installed.)
Removing deepin-anything-server (5.0.1-4) ...
userdel: user 'deepin-anything-server' does not exist
Failed on delete user deepin-anything-server
dpkg: error processing package deepin-anything-server (--remove):
installed deepin-anything-server package post-removal script subprocess returne
d error exit status 1
dpkg: too many errors, stopping
Processing was halted because there were too many errors.
E: Sub-process /usr/bin/dpkg returned an error code (1)"
If I try to remove this "deepin-anything-server" by itself or trying something like "sudo dpkg --configure -a" just gives me the same error. I'm kind of a noob and have no idea what to do. Any help would be greatly appreciated.
