Whenever I log in to Ubuntu, the brightness automatically goes to full. I'm using ubuntu 20.04 LTS with dual boot.
Any solution for this?
dipansh
  • 101
This can often be fixed by adding a setting to your Grub configuration. Try this:
  1. Open Terminal (if it is not already open)
  2. Edit the Grub configuration file:
    $ sudo vi /etc/default/grub
    Note: Feel free to use any text editor you prefer, so long as you are editing the file with sudo.
  3. Find the line that starts GRUB_CMDLINE_LINUX_DEFAULT and add acpi_backlight=vendor. This should give you a line that looks similar to this:
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
    Note: Your line may be longer with additional settings if you have an Nvidia video device or other hardware.
  4. Save the file and update Grub:
    $ sudo update-grub
  5. Reboot.
This should resolve the issue.
