I built a computer with an Aeorus B450x, Ryzen 3 2200G CPU with an integrated Vega 8 GPU, 2 x 8G RAM, and a 500GB SSD. The OS is Ubuntu 18.04. I've mostly used it for gaming via the Steam client. It has worked without issue until now.
It was in standby for a few hours today and when I entered my password to do some work nothing happened. I could move the cursor and enter characters, it just wouldn't open. When I reset the machine it froze on the Ubuntu loading screen. Now it either freezes on the loading screen or goes to black. I can boot from a USB though.
I had been learning to code Arduino before it went into standby. A SkillShare video was queued and Tinkercad circuits was open (I was simulating a circuit) in another window. I'm assuming that those programs running when it went into standby somehow caused an issue with the GPU, but I have played Boarder lands 2 on near maximum settings, so I don't know how those two windows could freeze the machine or why rebooting wouldn't solve the issue. When I boot from the USB the machine seems to run fine.
I held left Shift when booting, the screen went to black and I pressed Alt+ left arrow and saw an error with the GPU. I'm on my phone now, but I took a picture of the errors and copied the text and pasted it below. It seems like the error happens at different time during the boot process.
1 Stopped GNOME Display Manager.
Starting Detect the available GPUs and deal with any system changes...
.833734) blk_update_request: critical medium error, deu numeon1, sector 433668392 op .8502581 blk_update_request: critical medium error, deu numeon1, sector 433668392 op
.9748281 blk_update_request: critical medium error, dev numeon1, sector 433668392 op .9913341 blk_update_request: critical medium error, deu numeon1, sector 433668392 op
.1178231 blk_update_request: critical medium error, deu nume@n1, sector 433668392 1349901 blk_update_request: critical medium error, deu numeon1, sector 433668392 op
op
.2573261 blk_update_request: critical medium error, dev numeon1, sector 433668392 op
.2741211 blk_update_request: critical medium error, deu numeon1, sector 433668392 op
.3960813 blk_update_request: critical medium error, deu numeOn1, sector 433668392 op ( .4125801 blk_update_request: critical medium error, deu numeOn1, sector 433668392 op ( 1 Started Detect the available GPUs and deal with any system changes.
Starting GNOME Display Manager... 1 Started GNOME Display Manager.
Starting Accounts Service... Starting Authorization Manager...
DJ Failed to start Authorization Manager. systemctl status polkit.service for details.
1 Started Accounts Service.
1 Stopped GNOME Display Manager. Starting Detect the available GPUs and deal with any system changes...
.0833320 bik_update_request: critical medium error, deu numeon1, sector 433668392
op 0
.099823) blk_update_request: critical medium error, deu numeon1, sector 433668392 op 0 221273] blk_update_request: critical medium error, deu numeOn1, sector 433668392 op 0
.2384171 blk_update_request: critical medium error, deu numeOn1, sector 433668392 op 0 3669041 blk_update_request: critical medium error, deu numeon1, sector 433668392 op 0
.3837331 blk_update_request: critical medium error, deu numeon1, sector 433668392 op 0: .511149) blk_update_request: critical medium error, deu numeOn1, sector 433668392 op 0
.5276221 blk_update_request: critical medium error, deu numeOn1, sector 433668392 op 0 .651289) blk_update_request: critical medium error, deu nume@n1, sector 433668392 op 0 .667730) blk_update_request: critical medium error, deu numeon1, sector 433668392 op 0>
1 Started Detect the available CPUS and deal With an system changes
Fdisk command as requested:
ubuntu@ubuntu:~$ sudo fdisk -l Disk /dev/loop0: 1.9 GiB, 1987817472 bytes, 3882456 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 88.5 MiB, 92778496 bytes, 181208 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop2: 54.4 MiB, 57069568 bytes, 111464 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop3: 42.8 MiB, 44879872 bytes, 87656 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop4: 149.9 MiB, 157184000 bytes, 307000 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop5: 4 MiB, 4218880 bytes, 8240 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop6: 14.8 MiB, 15462400 bytes, 30200 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop7: 1008 KiB, 1032192 bytes, 2016 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/nvme0n1: 465.8 GiB, 500107862016 bytes, 976773168 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: E0D5BD46-7C96-4F9D-9678-D2250E4AEC0D
Device Start End Sectors Size Type /dev/nvme0n1p1 2048 1050623 1048576 512M EFI System /dev/nvme0n1p2 1050624 976771071 975720448 465.3G Linux filesystem
Disk /dev/sda: 7.5 GiB, 8004304896 bytes, 15633408 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x68f2002a
Device Boot Start End Sectors Size Id Type /dev/sda1 * 2048 15633407 15631360 7.5G c W95 FAT32 (LBA)
Disk /dev/loop8: 3.7 MiB, 3825664 bytes, 7472 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
This is what happens when I try an alternate block:
ubuntu@ubuntu:-$ sudo e2fsck -b 32768 /dev/nvmeOn1 e2fsck 1.44.1 (24-Mar-2018)
e2fsck: Bad magic number in super-block while trying to open /dev/nvnen1
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem. If the device is valid and it really contains an ext2/ext3/ext4 filesystem (and not swap or ufs or something else), then the superblock is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 or
e2fsck -b 32768
Found a gpt partition table in /dev/nvme0n1
Smartctl output as requested:
ubuntu@ubuntu:~$ sudo smartctl -a /dev/nvme0n1 smartctl 6.6 2016-05-31 r4324 [x86_64-linux-5.0.0-23-generic] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION === Model Number: CT500P1SSD8 Serial Number: 1940E222A6B5 Firmware Version: P3CR013 PCI Vendor/Subsystem ID: 0xc0a9 IEEE OUI Identifier: 0x00a075 Controller ID: 1 Number of Namespaces: 1 Namespace 1 Size/Capacity: 500,107,862,016 [500 GB] Namespace 1 Formatted LBA Size: 512 Local Time is: Thu Feb 4 13:19:36 2021 UTC Firmware Updates (0x14): 2 Slots, no Reset required Optional Admin Commands (0x0016): Format Frmw_DL Other Optional NVM Commands (0x005e): Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat Other Maximum Data Transfer Size: 32 Pages Warning Comp. Temp. Threshold: 70 Celsius Critical Comp. Temp. Threshold: 80 Celsius
Supported Power States St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat 0 + 9.00W - - 0 0 0 0 5 5 1 + 4.60W - - 1 1 1 1 30 30 2 + 3.80W - - 2 2 2 2 30 30 3 - 0.0500W - - 3 3 3 3 1000 1000 4 - 0.0040W - - 4 4 4 4 6000 8000
Supported LBA Sizes (NSID 0x1) Id Fmt Data Metadt Rel_Perf 0 + 512 0 0
=== START OF SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02, NSID 0x1) Critical Warning: 0x00 Temperature: 35 Celsius Available Spare: 100% Available Spare Threshold: 10% Percentage Used: 0% Data Units Read: 116,491,813 [59.6 TB] Data Units Written: 1,678,571 [859 GB] Host Read Commands: 757,713,041 Host Write Commands: 25,945,048 Controller Busy Time: 2,017 Power Cycles: 50 Power On Hours: 9,524 Unsafe Shutdowns: 26 Media and Data Integrity Errors: 43,137 Error Information Log Entries: 0 Warning Comp. Temperature Time: 0 Critical Comp. Temperature Time: 0 Temperature Sensor 1: 35 Celsius Temperature Sensor 2: 35 Celsius Temperature Sensor 5: 43 Celsius
Read Error Information Log failed: NVMe Status 0x02
Ubuntu has a problem with your block device aka Harddisk.
This seems to be a severe error, so I'd grab an USB with a live cd, boot into your PC and check your hard drives. First try to "fix" the partitions using e2fsck -f -y -v /dev/sdXX (like /dev/sda1, depends on your system)
If done use smartctl to check about the health of that device
Update To list all devices you should execute fdisk -l (the l stands for list and is NOT a 1)
It seems that the superblock is broken and needs to be fixed. But:
/dev/sda is your usb stick, do not work with that device! So efsck dev/sda will not work.
It looks like you are having a nvme drive:
Disk /dev/nvme0n1p1
So you'll have to work on this drive....
kanehekili
  • 7,426
