I need to use my Logitech Streamcam webcam at 1080p (1920x1080) at 60fps but it neither work in OBS Studio, nor in guvcview nor if I want to save the output as a video file, ffmpeg freezes :( Thanks in advance for you help.
** Update (2) 3rd February: new dmesg info/data
OBS Studio
The following steps work without problem but if I change to 1080p and/or 60fps, ffmpeg freezes.
# sudo modprobe v4l2loopback
# ffmpeg -f v4l2 -input_format mjpeg -framerate 30 -s 1280x720 -i /dev/video0 -pix_fmt yuyv422 -f v4l2 /dev/video2
Ffmpeg => Video file 720p@30
# ffmpeg -f v4l2 -input_format mjpeg -framerate 30 -s 1280x720 -i /dev/video0 -pix_fmt yuvj422p video-test-output.mp4
Ffmpeg => Video file 1080p@30
With the following steps ffmpeg freezes
# ffmpeg -f v4l2 -input_format mjpeg -framerate 30 -s 1920x1080 -i /dev/video0 -pix_fmt yuvj422p video-test-output.mp4
ffmpeg version 4.1.4-1build2 Copyright (c) 2000-2019 the FFmpeg developers
built with gcc 9 (Ubuntu 9.2.1-4ubuntu1)
configuration: --prefix=/usr --extra-version=1build2 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil 56. 22.100 / 56. 22.100
libavcodec 58. 35.100 / 58. 35.100
libavformat 58. 20.100 / 58. 20.100
libavdevice 58. 5.100 / 58. 5.100
libavfilter 7. 40.101 / 7. 40.101
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 3.100 / 5. 3.100
libswresample 3. 3.100 / 3. 3.100
libpostproc 55. 3.100 / 55. 3.100
[video4linux2,v4l2 @ 0x55cf92dc5ac0] Could not find codec parameters for stream 0 (Video: mjpeg, none(bt470bg/unknown/unknown), 1920x1080): unspecified pixel format
Consider increasing the value for the 'analyzeduration' and 'probesize' options
Input #0, video4linux2,v4l2, from '/dev/video0':
Duration: N/A, bitrate: N/A
Stream #0:0: Video: mjpeg, none(bt470bg/unknown/unknown), 1920x1080, 30 fps, 30 tbr, 1000k tbn, 1000k tbc
Stream mapping:
Stream #0:0 -> #0:0 (mjpeg (native) -> h264 (libx264))
Press [q] to stop, [?] for help
Cannot determine format of input stream 0:0 after EOF
Error marking filters as finished
Exiting normally, received signal 2.
Test (1) I tried to change the webcam settings to 1080p but it didn't work.
# v4l2-ctl --device /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=MJPG
Additional info/data that it could be useful
# uname -r
5.3.0-64-generic
# dmesg
[ 5.120382] usb 2-8: current rate 16000 is different from the runtime rate 48000
[ 5.121990] snd_hda_codec_realtek hdaudioC2D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[ 5.121992] snd_hda_codec_realtek hdaudioC2D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 5.121993] snd_hda_codec_realtek hdaudioC2D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 5.121994] snd_hda_codec_realtek hdaudioC2D0: mono: mono_out=0x0
[ 5.121995] snd_hda_codec_realtek hdaudioC2D0: dig-out=0x1e/0x0
[ 5.121995] snd_hda_codec_realtek hdaudioC2D0: inputs:
[ 5.121997] snd_hda_codec_realtek hdaudioC2D0: Front Mic=0x19
[ 5.121998] snd_hda_codec_realtek hdaudioC2D0: Rear Mic=0x18
[ 5.121998] snd_hda_codec_realtek hdaudioC2D0: Line=0x1a
[ 5.141136] uvcvideo: Found UVC 1.00 device Logitech StreamCam (046d:0893)
[ 5.157490] uvcvideo 2-8:1.0: Entity type for entity Processing 3 was not initialized!
[ 5.157493] uvcvideo 2-8:1.0: Entity type for entity Extension 14 was not initialized!
[ 5.157495] uvcvideo 2-8:1.0: Entity type for entity Extension 6 was not initialized!
[ 5.157496] uvcvideo 2-8:1.0: Entity type for entity Extension 8 was not initialized!
[ 5.157498] uvcvideo 2-8:1.0: Entity type for entity Extension 9 was not initialized!
[ 5.157499] uvcvideo 2-8:1.0: Entity type for entity Extension 10 was not initialized!
[ 5.157500] uvcvideo 2-8:1.0: Entity type for entity Extension 11 was not initialized!
[ 5.157502] uvcvideo 2-8:1.0: Entity type for entity Camera 1 was not initialized!
[ 5.157583] input: Logitech StreamCam as /devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb2/2-8/2-8:1.0/input/input32
[ 5.157671] usbcore: registered new interface driver uvcvideo
[ 5.157672] USB Video Class driver (1.1.1)
3rd February 2021: I plug in the webcam after my computer has fully loaded and this is the dmesg info:
# dmesg
[ 553.490310] usb 2-7: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 553.517111] usb 2-7: New USB device found, idVendor=046d, idProduct=0893, bcdDevice= 3.17
[ 553.517114] usb 2-7: New USB device strings: Mfr=0, Product=2, SerialNumber=3
[ 553.517116] usb 2-7: Product: Logitech StreamCam
[ 553.517118] usb 2-7: SerialNumber: XR6W1K92
[ 553.541903] usb 2-7: current rate 16000 is different from the runtime rate 24000
[ 553.548111] usb 2-7: current rate 16000 is different from the runtime rate 32000
[ 553.554401] usb 2-7: current rate 16000 is different from the runtime rate 48000
[ 553.573341] hid-generic 0003:046D:0893.0008: hiddev5,hidraw7: USB HID v1.11 Device [Logitech StreamCam] on usb-0000:02:00.0-7/input5
[ 553.629854] videodev: Linux video capture interface: v2.00
[ 553.642019] uvcvideo: Found UVC 1.00 device Logitech StreamCam (046d:0893)
[ 553.657973] uvcvideo 2-7:1.0: Entity type for entity Processing 3 was not initialized!
[ 553.657975] uvcvideo 2-7:1.0: Entity type for entity Extension 14 was not initialized!
[ 553.657977] uvcvideo 2-7:1.0: Entity type for entity Extension 6 was not initialized!
[ 553.657978] uvcvideo 2-7:1.0: Entity type for entity Extension 8 was not initialized!
[ 553.657979] uvcvideo 2-7:1.0: Entity type for entity Extension 9 was not initialized!
[ 553.657981] uvcvideo 2-7:1.0: Entity type for entity Extension 10 was not initialized!
[ 553.657982] uvcvideo 2-7:1.0: Entity type for entity Extension 11 was not initialized!
[ 553.657983] uvcvideo 2-7:1.0: Entity type for entity Camera 1 was not initialized!
[ 553.658054] input: Logitech StreamCam as /devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb2/2-7/2-7:1.0/input/input32
[ 553.658127] usbcore: registered new interface driver uvcvideo
[ 553.658128] USB Video Class driver (1.1.1)
[ 553.724131] usb 2-7: current rate 16000 is different from the runtime rate 48000
[ 553.737390] usb 2-7: current rate 16000 is different from the runtime rate 48000
[ 553.755142] usb 2-7: current rate 16000 is different from the runtime rate 48000
# lsusb
Bus 002 Device 002: ID 046d:0893 Logitech, Inc. Logitech StreamCam
# v4l2-ctl -V
Format Video Capture:
Width/Height : 1280/720
Pixel Format : 'MJPG' (Motion-JPEG)
Field : None
Bytes per Line : 0
Size Image : 1843200
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
# v4l2-ctl --list-devices
Logitech StreamCam (usb-0000:02:00.0-8):
/dev/video0
/dev/video1
# v4l2-ctl --list-formats-ext -d /dev/video0
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.042s (24.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Interval: Discrete 0.200s (5.000 fps)
Size: Discrete 1920x1080
Size: Discrete 2304x1296
[1]: 'MJPG' (Motion-JPEG, compressed)
Interval: Discrete 0.017s (60.000 fps)
[2]: 'NV12' (Y/CbCr 4:2:0)
