I have a CIFS mount that was working but has broken. It still mounts with sudo mount -a but not at boot. The CIFS share is hosted on openmediavault 5 on a raspberry pi 4. I'm not seeing any errors in the OMV logs.
My fstab entry looks like this:
//192.168.1.97/sharedrive /media/Nas cifs credentials=/home/brad/.smbcredentials,vers=3,_netdev,iocharset=utf8,auto,forceuid,forcegid,uid=1000,gid=5000,file_mode=0777,dir_mode=0777 0 0
DMESG output looks like this:
CIFS: Attempting to mount //192.168.1.97/sharedrive
CIFS VFS: Error connecting to socket. Aborting operation.
CIFS VFS: cifs_mount failed w/return code = -2
JOURNALCTL output looks like this:
systemd[1]: media-Nas.mount: Mount process exited, code=exited, status=32/n/a
systemd[1]: media-Nas.mount: Failed with result 'exit-code'.
systemd[1]: Failed to mount Mount CIFS Share.
Any help would be hugely appreciated. Thanks!
edit:
output of systemctl status NetworkManager-wait-online.service
● NetworkManager-wait-online.service - Network Manager Wait Online
     Loaded: loaded (/lib/systemd/system/NetworkManager-wait-online.service; enabled; vendor preset: enabled)
     Active: active (exited) since Fri 2021-01-29 17:42:32 EST; 43min ago
       Docs: man:nm-online(1)
    Process: 806 ExecStart=/usr/bin/nm-online -s -q --timeout=30 (code=exited, status=0/SUCCESS)
   Main PID: 806 (code=exited, status=0/SUCCESS)
Jan 29 17:42:26 HP-Laptop systemd[1]: Starting Network Manager Wait Online... Jan 29 17:42:32 HP-Laptop systemd[1]: Finished Network Manager Wait Online.
output of systemd-networkd-wait-online
systemctl status systemd-networkd-wait-online
● systemd-networkd-wait-online.service - Wait for Network to be Configured
     Loaded: loaded (/lib/systemd/system/systemd-networkd-wait-online.service; disabled; vendor preset: enabled)
     Active: inactive (dead)
       Docs: man:systemd-networkd-wait-online.service(8)
edit 2:
     Loaded: loaded (/lib/systemd/system/systemd-networkd-wait-online.service; enabled; vendor preset: enabled)
     Active: active (exited) since Fri 2021-01-29 18:42:00 EST; 3min 54s ago
    Process: 444 ExecStart=/lib/systemd/systemd-networkd-wait-online (code=exited, status=0/SUCCESS)
   Main PID: 444 (code=exited, status=0/SUCCESS)
Jan 29 18:42:00 HP-Laptop systemd[1]: Starting Wait for Network to be Configured... Jan 29 18:42:00 HP-Laptop systemd[1]: Finished Wait for Network to be Configured.
EDIT 3:
The output of systemctl status networkd-dispatcher.service systemd-networkd.service
● networkd-dispatcher.service - Dispatcher daemon for systemd-networkd
     Loaded: loaded (/lib/systemd/system/networkd-dispatcher.service; enabled; vendor preset: enabled)
     Active: active (running) since Fri 2021-01-29 19:19:51 EST; 1min 20s ago
   Main PID: 747 (networkd-dispat)
      Tasks: 1 (limit: 9072)
     Memory: 19.7M
     CGroup: /system.slice/networkd-dispatcher.service
             └─747 /usr/bin/python3 /usr/bin/networkd-dispatcher --run-startup-triggers
Jan 29 19:19:51 HP-Laptop systemd[1]: Starting Dispatcher daemon for systemd-networkd... Jan 29 19:19:51 HP-Laptop systemd[1]: Started Dispatcher daemon for systemd-networkd. Jan 29 19:19:57 HP-Laptop networkd-dispatcher[747]: WARNING:Unknown index 3 seen, reloading interface list Jan 29 19:20:00 HP-Laptop networkd-dispatcher[747]: WARNING:Unknown index 5 seen, reloading interface list Jan 29 19:20:00 HP-Laptop networkd-dispatcher[747]: WARNING:Unknown index 6 seen, reloading interface list
● systemd-networkd.service - Network Service Loaded: loaded (/lib/systemd/system/systemd-networkd.service; enabled; vendor preset: enabled) Active: active (running) since Fri 2021-01-29 19:19:49 EST; 1min 22s ago TriggeredBy: ● systemd-networkd.socket Docs: man:systemd-networkd.service(8) Main PID: 431 (systemd-network) Status: "Processing requests..." Tasks: 1 (limit: 9072) Memory: 4.1M CGroup: /system.slice/systemd-networkd.service └─431 /lib/systemd/systemd-networkd
Your fstab entry looks okay and should work fine.
It ,however. appears that the mount is attempted prior to network connectivity becomes available ( systemd's connectivity in particular ). Hence these errors:
and
systemd[1]: media-Nas.mount: Mount process exited, code=exited, status=32/n/a systemd[1]: media-Nas.mount: Failed with result 'exit-code'. systemd[1]: Failed to mount Mount CIFS Share.
This is due to the service systemd-networkd-wait-online being disabled.
Enable the service like so:
sudo systemctl enable systemd-networkd-wait-online
This should execute without errors.
After that reboot your system. Your network share should mount at boot now.
If the share is still not mounting, check:
And see if either service is disabled and enable them too. Then reboot your system.
Raffa
  • 34,963
I too was having exact same issue. Though in my case CIFS share is hosted on ASUS RT AC68U with DD WRT 3.0
Here's how I solved the issue:
(1) Enabled these services (as I've disabled these in the past):
sudo systemctl enable systemd-networkd.service
sudo systemctl enable NetworkManager-wait-online.service
Note: If any of those services are masked, then you would need to first unmask, and then enable it.
You can find more on how to properly unmask here: [1] and [2].
(2) I commented out (removed) fstab entry for CIFS share, and created systemd mount for cifs share:
Note: Create a new file media-admn-nas.mount in the diretory /etc/systemd/system.
The filename must contain the mount point name where the slashes are replaced with “minus”. Mount-directory /media/admn/nas => media-admn-nas.mount
sudo nano /etc/systemd/system/media-admn-nas.mount
[Unit]
Description=CIFS Mount Service
Requires=network-online.target systemd-networkd.service
After=network-online.target network-online.service media-admn-1\x2d6TB.mount remote-fs.target
Wants=network-online.target NetworkManager-wait-online.service
[Mount] What=//192.168.1.1/nas Where=/media/admn/nas Options=rw,_netdev,auto,cache=none,vers=3.11,credentials=/home/admn/.smbcredentials,forceuid,forcegid,uid=1000,gid=1000 Type=cifs TimeoutSec=15
[Install] WantedBy=multi-user.target
Note-1: In my case, media-admn-1\x2d6TB.mount is an additional hard drive where I have mounted the cifs share, so I've added that as After= requirement.
Note-2: As I was still getting errors, I've added TimeoutSec=15
(3) Enable the mount:
sudo systemctl enable media-admn-nas.mount
sudo systemctl daemon-reload
(4) Reboot: 15 sec after a reboot, CIFS share should be mounted.
(5) Check status:
$ systemctl status media-admn-nas.mount
● media-admn-nas.mount - CIFS Mount Service
     Loaded: loaded (/etc/systemd/system/media-admn-nas.mount; enabled; vendor preset: enable>
     Active: active (mounted) since Sun 2021-01-31 10:37:52 IST; 1h 58min ago
      Where: /media/admn/nas
       What: //192.168.1.1/nas
      Tasks: 0 (limit: 19083)
     Memory: 12.0K
     CGroup: /system.slice/media-admn-nas.mount
Jags
  • 2,235
  • 28
  • 44
