I have problem with installing new updates on my ubuntu. While researching I came up to my conclusion that /boot/ is full at 100%, not even auto-remove works (says run apt-fix install first) when i run apt-fix it errors.
Use dpkg instead of apt to remove some of those packages.
Then try apt autoremove again.
- 68,493
Your screenshot shows that old kernels have accumulated, filling up /boot with kernel images (/boot/vmlinuz*) and initial RAM disks (/boot/initrd.img*).
Typically you will want to keep the newest two or three and get rid of the others.
The clean and recommended way is to identify what package they belong to and then uninstall that package; e.g.
[sh @ balrog] ~ 1 % ls -lh /boot
total 103M
-rw-r--r-- 1 root root 39M Jan 29 15:03 initrd.img-4.15.0-134-generic
-rw-r--r-- 1 root root 39M Jan 29 15:05 initrd.img-4.15.0-135-generic
-rw------- 1 root root 8,0M Jan 15 11:32 vmlinuz-4.15.0-134-generic
-rw------- 1 root root 8,1M Jan 18 18:24 vmlinuz-4.15.0-135-generic
[sh @ balrog] ~ 2 % dpkg -S /boot/vmlinuz-4.15.0-134-generic
linux-image-4.15.0-134-generic: /boot/vmlinuz-4.15.0-134-generic
And if you decide this is one you want to get rid of, uninstall it with
sudo dpkg -r linux-image-...
Notice that /boot/initrd.img* are not owned by any package because they are generated on the fly depending on what kernel modules you need in your current configuration, so dpkg -S on them will always return "no path found matching pattern..."; so concentrate on /boot/vmlinuz*.
After that, make sure to tell the bootloader about it:
sudo update-grub
Otherwise stale menu entries will remain in the Grub menu (until the next update bringing a new kernel which will also trigger this).
HTH
- 3,525
