I want to have Nextcloud start when I open my session. Following the instructions to start applications automatically does not work for me; I have to start Nextcloud manually each time I start my session.
I am using Ubuntu 20.04 and Nextcloud client 2.6.5
Edit: clicking the option in the Nextcloud Client General Settings did not work
My way to add a program on user session startup is firstly install gnome-tweaks.
sudo apt install gnome-tweaks
Then run it from activity menu, and go top Startup program, click on the + to add a new program, then choose Nextcloud from the list.
ob2
  • 3,653
It should be under the Nextcloud Client General Settings. Click the box to put a check on the option to "Launch on System Startup"
It works, if you do it as root.
For me, all I had to do is add the user who started up the system to the sudoers:
sudo usermod -a -G sudo <user_who_started_the_system>
Have a look at: https://devconnected.com/how-to-add-user-to-sudoers-on-ubuntu-20-04 to get some more instructions.
Pizza
  • 1,512
Ingo
