I'm currently using Ubuntu 20.04 LTS. I'm having way too many issues with my computer right now, but I will start with trying to fix my WiFi. So I tried to install net-tools, but then this happened.
    patrick@patrick-Swift-SF315-51G:~$ sudo apt install net-tools
[sudo] password for patrick:
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
 libc6-dbg : Depends: libc6 (= 2.31-0ubuntu9.2) but 2.31-0ubuntu9.1 is to be installed
 libc6-dev : Depends: libc6 (= 2.31-0ubuntu9.2) but 2.31-0ubuntu9.1 is to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I tried this: apt --fix-broken install & apt-get -f install - received the same answer.
patrick@patrick-Swift-SF315-51G:~$ apt --fix-broken install
E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
I also have received a notification from my Package Manager: The package system is broken
Check if you are using third party repositories. If so, disable them since they are a common source of problems. Furthermore, run the following command in a Terminal: apt-get install -f
  libc6-dbg: Depends: libc6 (= 2.31-0ubuntu9.2) but 2.31-0ubuntu9.1 is installed
    libc6-dev: Depends: libc6 (= 2.31-0ubuntu9.2) but 2.31-0ubuntu9.1 is installed
               Depends: libc-dev-bin (= 2.31-0ubuntu9.2) but 2.31-0ubuntu9.2 is installed
So my question is, how can I fix the broken packages and use Sudo apt-get install again?
Thank you for your time.
Edit: I tried sudo apt-get clean & sudo apt-get update Then I tried Sudo apt-get -f install, same result.
 /var/cache/apt/archives/libc6_2.31-0ubuntu9.2_amd64.deb
 /var/cache/apt/archives/libc6_2.31-0ubuntu9.2_i386.deb
I also tried to sudo dpkg --configure -a; and received this
dpkg: dependency problems prevent configuration of libc6-dbg:amd64:
 libc6-dbg:amd64 depends on libc6 (= 2.31-0ubuntu9.2); however:
  Version of libc6:amd64 on system is 2.31-0ubuntu9.1.
dpkg: error processing package libc6-dbg:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libc6-dev:amd64: libc6-dev:amd64 depends on libc6 (= 2.31-0ubuntu9.2); however: Version of libc6:amd64 on system is 2.31-0ubuntu9.1.
dpkg: error processing package libc6-dev:amd64 (--configure): dependency problems - leaving unconfigured Processing triggers for libc-bin (2.31-0ubuntu9.1) ... Errors were encountered while processing: libc6-dbg:amd64 libc6-dev:amd64
Try the following workflow
sudo apt-get clean
sudo apt-get update
sudo apt-get -f install
