[Edit] THE ANSWER:
It was my mistake I accidently unistalled python and that's why all the apps that used python (Almost all) were gone, no solution on the internet worked so finally I had to reinstall it
I was installing python3 on my ubuntu 20.04 (dual-booted with windows 10) when I was installing it suddenly something happened and the terminal closed and disappeared from the favourites then I looked into All Apps section, I saw that many apps (I think they were the default apps) including the Terminal disappeared then I thought a reboot would work so I did it and when it was booting I saw some errors
ACPI BIOS Error (BUG) : Can not resolve symbol [SOME SORT OF CODE]
☝ This was written multiple times and at the end of these, Something like this was written:
dev/sda5/something/something...
I don't know what it was written because it showed just for around 5-6 seconds After this ubuntu booted and showed a popup and its title was: "Sorry, Ubuntu 20.04 has experienced an internal error"
It was happening in every boot. So, I removed ubuntu from dual boot I removed it's partition and GRUB (I am a bit unsure about the GRUB but it does not shows up on boot so I think it is removed)
And now I want to install Linux again (This time Pop OS) can anyone tell why that happened and what is the solution and how can I prevent it from happening again.
I hope I will get the Answer. Thanks.
Some Information:
  • I am using a HDD
  • I have a Legacy BIOS
  • My PC uses MBR
  • dev/sda5 is my root.
  • I didn't added any home folder Linux managed that with the root partition.
  • I added a different 10GB partition for Linux swap.
  • I installed the GRUB bootloader in the dev/sda5 partition instead of the actual hard disk (dev/sda).
  • I used EasyBCD to boot from dev/sda5 because it will boot from the windows boot manager because as I said I didn't installed it on the whole hard disk.
Unnat
  • 165
Unnat
  • 165
