I am having an issue with installing virtualbox 6.1 using apt with Ubuntu 20.04 OS. I used this tutorial to get all the way to the last step with the command
$ sudo apt install virtualbox-6.1
which is giving me an error of
Reading package lists... Done
Building dependency tree
virtualbox-6.1 : Depends: python (< 2.8) but it is not installable
Depends: python (>= 2.7) but it is not installable
Depends: python:any (>= 2.6.6-7~)
Recommends: libsdl-ttf2.0-0 but it is not installable
The apt-cache policy virtualbox-6.1 is this.
Installed: (none)
Candidate: 6.1.18-142142~Ubuntu~eoan
Version table:
6.1.18-142142~Ubuntu~eoan 500
500 https://download.virtualbox.org/virtualbox/debian eoan/contrib amd64 Packages
6.1.16-140961~Ubuntu~eoan -1
100 /var/lib/dpkg/status
It is still having the python issue it looks like
$ python --version
Python 3.8.5
$ python3 --version
Python 3.8.5
$ dpkg -l python
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
rc python 2.7.17-1 amd64 interactive high-level object-oriented language (Python2 version)
$ dpkg -l python3
ii python3 3.8.2-0ubuntu2 amd64 interactive high-level object-oriented language (default python3 version)
