10
I'm not a novice, I could find a ppa or just compile it but I like to keep my systems tidy. So with that being said, when will Gimp 2.8 come to the software repository?
Also, rather than just getting the answer is there a place on the Ubuntu interwebs some where that I can check the status for other packages as well?
Or is this all done internally at Canonical?
Mike Haas
  • 796
In October 2012, as part of the 12.10 release.
(GIMP 2.8 was released on 3rd May 2012. The 12.10 release is the first after this date. And 12.10 definitely contains version 2.8.)
8128
  • 28,868
Exceedingly well managed projects have target dates for versions on their project roadmap. It appears as of this time that GIMP does not.
Something you can see easily is if the version you want has been packaged in the alpha/beta of the next release. If it is, you may have some luck in features showing up in backports(although not full version updates...versions freeze for stability reasons). This is not a definitive answer, but it is what I surmise from my somewhat limited experience in working with proper package management(as opposed to just building what I need).
Related question:
RobotHumans
  • 30,112
From your question, I'm not sure 100% what you are want. You suggest you don't want a ppa, but ask when it'll be in "the software repository"? Well, it's in the launchpad repositories. We're having a discussion here, but essentially, you can install 2.8.0 via ppa:otto-kesselgulasch/gimp (see the web link here). Note that it has the following warning: "CAUTION! This PPA could break your installed OS. There are dependency issues especially for Oneiric (11.10). Only use it if you know what you do! I'm working with others on a stable and reliable solution."
Sparhawk
  • 6,969
Gimp 2.8 will likely be available in the backports repository
You can follow progress on this bug report:
https://bugs.launchpad.net/precise-backports/+bug/1002780
In the interim you can install it from this ppa
https://launchpad.net/~laney/+archive/ppa
For information on what backports are see: https://help.ubuntu.com/community/UbuntuBackports
Panther
  • 104,528
