52
In 12.04 How do you kill the X server from the command line and from the GUI interface and how do you start it from the virtual terminal?
Jorge Castro
  • 73,717
Robert
  • 653
6 Answers6
42
One way to restart an instance of the X server is to run (from the commandline)
sudo service lightdm restart
For Ubuntu 15.04 and later:
sudo systemctl restart lightdm.service
and for Kubuntu 15.04 and later:
sudo systemctl stop sddm.service
Carolus
  • 600
labarna
  • 2,632
21
On 12.04, you can restart the server with the shortcut keys: Right Alt + Print Screen + K.
Mike Haas
  • 796
14
In Ubuntu 14.04:
Press Ctrl+Alt+F1 and then run:
sudo service gdm stop
or
sudo service lightdm stop
… depending on your display manager.
NOTE: To recover use startx, alternatively replace the stop with start in either of the above commands.
dessert
  • 40,956
bhass1
  • 396
Kill : xkill -a. -a means it will kill all display instances. For more information run man xkill.
Run : xinit. Also startx but this command is to start an instance and not the server itself. For more information run man xint and man startx.
I don't believe it's possible to kill Xserver from GUI, and even if it were, it would not be the right way to do it.
Jack Mayerz
  • 1,687
On Ubuntu 22.04 (and a few previous versions) you can add a hotkey to your gnome session to kill the x server. Install gnome-tweaks via sudo apt install gnome-tweaks and then open it (logo button and then "tweaks" and enter) then goto "Keyboard & Mouse" -> "Additional Layout Options" -> "Key sequence to kill the X server" -> "Ctrl+Alt+Backspace"
Grifball
  • 101
On more recent versions of Ubuntu (e.g. 22.04) which use Gnome and systemd, you can use:
$ sudo systemctl restart gdm.service
Adam
