I want to install 2 Oh My Zsh plugins, but I don't know their names. My brother had also downloaded them some years ago, but he doesn't know their names either.
How can I know what Oh My Zsh plugins are installed in my brother's zsh?
I suppose that you installed Oh My Zsh by running the following command:
sh -c "$(wget https://raw.github.com/ohmyzsh/ohmyzsh/master/tools/install.sh -O -)"
In this case, Oh My Zsh plugins are installed in the ~/.oh-my-zsh/plugins directory, so running the following command will return a list of your installed plugins:
ls ~/.oh-my-zsh/plugins
To enable a plugin, just add its name (as shown from the above command) in plugins=(...) in your ~/.zshrc file. From the Oh My Zsh wiki:
Enable a plugin by adding its name to the plugins array in your
.zshrcfile (found in the$HOMEdirectory). For example, this enables therails,gitandrubyplugins, in that order:plugins=(rails git ruby)
You can list the enabled plugins with:
echo $plugins
There's another way of listing and enabling/disabling installed plugins using the omz command.
To list installed plugins you can run:
omz plugin list
To enable a plugin you can run:
omz plugin enable <plugin>
where <plugin> is the name of the plugin you wish to enable. For example, to enable the common-aliases plugin, you would run:
omz plugin enable common-aliases
To disable a plugin you can run:
omz plugin disable <plugin>
For example, to disable the common-aliases plugin, you would run:
omz plugin disable common-aliases
The omz command is pretty handy and can also be used to obtain information about a plugin:
omz plugin info <plugin>
For example, running omz plugin info ufw returns information about the ufw plugin:
# UFW plugin
This plugin adds completion for managing everybody's favorite Uncomplicated Firewall (UFW),
a simple interface for managing iptables. Learn more about UFW.
To use it, add ufw to the plugins array of your zshrc file:
plugins=(... ufw)
Some of the commands include:
allow <port>/<optional: protocol> add an allow rule
default set default policy
delete <port>/<optional: protocol> delete RULE
deny <port>/<optional: protocol> add deny rule
disable disables the firewall
enable enables the firewall`
For more information about omz's usage you can run:
omz --help
