The problem started when I tried to uninstall/install python2/python3. Terminal/Firefox were removed, I don't know how.
Then I rebooted the system. Now I am unable to login as the error was
I tried to upgrade and update through various commands like:
sudo apt update
The message I am constantly getting is:
karel
  • 122,292
  • 133
  • 301
  • 332
It looks like you don't have any network access in your second screen "could not resolve". Try to plug the Ethernet cable or I found this tutorial to use the wifi with command line and try again. Otherwise you could also try to also check your DNS (and maybe replace it by 1.1.1.1 to try)
Let us know
Fl_ori4n
  • 176
You killed off a critical service that all these others need. The quickest way to fix it and the most reliable is a fresh install.
David DE
  • 2,316
