I don't know why this error coming. and this one is normal?
os : 5.8.0-38-generic #43~20.04.1-Ubuntu
my Terminal Output:
kaushal@kaushal:~$ sudo apt upgrade Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages were automatically installed and are no longer required: fonts-lato gstreamer1.0-vaapi javascript-common libdislocker0.7 libgstreamer-plugins-bad1.0-0 libjs-jquery libllvm10 libllvm10:i386 libmbedcrypto3 libruby2.7 rake ruby ruby-minitest ruby-net-telnet ruby-power-assert ruby-test-unit ruby-xmlrpc ruby2.7 rubygems-integration ubuntu-restricted-addons Use 'sudo apt autoremove' to remove them. The following packages will be upgraded: libnetplan0 libnss-systemd libpam-systemd libsystemd0 libsystemd0:i386 libudev1 libudev1:i386 linux-firmware netplan.io systemd systemd-sysv systemd-timesyncd udev 13 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 108 MB of archives. After this operation, 74.8 kB of additional disk space will be used. Do you want to continue? [Y/n] y Get:1 http://in.archive.ubuntu.com/ubuntu focal-updates/main amd64 libnss-systemd amd64 245.4-4ubuntu3.4 [95.9 kB] Get:2 http://in.archive.ubuntu.com/ubuntu focal-updates/main amd64 libudev1 amd64 245.4-4ubuntu3.4 [80.3 kB] Get:3 http://in.archive.ubuntu.com/ubuntu focal-updates/main i386 libudev1 i386 245.4-4ubuntu3.4 [83.1 kB] Get:4 http://in.archive.ubuntu.com/ubuntu focal-updates/main amd64 udev amd64 245.4-4ubuntu3.4 [1,365 kB] Get:5 http://in.archive.ubuntu.com/ubuntu focal-updates/main amd64 systemd-timesyncd amd64 245.4-4ubuntu3.4 [28.1 kB] Get:6 http://in.archive.ubuntu.com/ubuntu focal-updates/main amd64 systemd-sysv amd64 245.4-4ubuntu3.4 [10.3 kB] Get:7 http://in.archive.ubuntu.com/ubuntu focal-updates/main amd64 libpam-systemd amd64 245.4-4ubuntu3.4 [186 kB] Get:8 http://in.archive.ubuntu.com/ubuntu focal-updates/main amd64 systemd amd64 245.4-4ubuntu3.4 [3,805 kB] Get:9 http://in.archive.ubuntu.com/ubuntu focal-updates/main i386 libsystemd0 i386 245.4-4ubuntu3.4 [292 kB] Get:10 http://in.archive.ubuntu.com/ubuntu focal-updates/main amd64 libsystemd0 amd64 245.4-4ubuntu3.4 [273 kB] Get:11 http://in.archive.ubuntu.com/ubuntu focal-updates/main amd64 libnetplan0 amd64 0.101-0ubuntu3~20.04.2 [28.5 kB] Get:12 http://in.archive.ubuntu.com/ubuntu focal-updates/main amd64 netplan.io amd64 0.101-0ubuntu3~20.04.2 [94.2 kB] Get:13 http://in.archive.ubuntu.com/ubuntu focal-updates/main amd64 linux-firmware all 1.187.8 [102 MB] Fetched 108 MB in 56s (1,926 kB/s) (Reading database ... 203312 files and directories currently installed.) Preparing to unpack .../libnss-systemd_245.4-4ubuntu3.4_amd64.deb ... Unpacking libnss-systemd:amd64 (245.4-4ubuntu3.4) over (245.4-4ubuntu3.3) ... Preparing to unpack .../libudev1_245.4-4ubuntu3.4_i386.deb ... De-configuring libudev1:amd64 (245.4-4ubuntu3.3) ... Unpacking libudev1:i386 (245.4-4ubuntu3.4) over (245.4-4ubuntu3.3) ... Preparing to unpack .../libudev1_245.4-4ubuntu3.4_amd64.deb ... Unpacking libudev1:amd64 (245.4-4ubuntu3.4) over (245.4-4ubuntu3.3) ... Setting up libudev1:amd64 (245.4-4ubuntu3.4) ... Setting up libudev1:i386 (245.4-4ubuntu3.4) ... (Reading database ... 203312 files and directories currently installed.) Preparing to unpack .../0-udev_245.4-4ubuntu3.4_amd64.deb ... Unpacking udev (245.4-4ubuntu3.4) over (245.4-4ubuntu3.3) ... Preparing to unpack .../1-systemd-timesyncd_245.4-4ubuntu3.4_amd64.deb ... Unpacking systemd-timesyncd (245.4-4ubuntu3.4) over (245.4-4ubuntu3.3) ... Preparing to unpack .../2-systemd-sysv_245.4-4ubuntu3.4_amd64.deb ... Unpacking systemd-sysv (245.4-4ubuntu3.4) over (245.4-4ubuntu3.3) ... Preparing to unpack .../3-libpam-systemd_245.4-4ubuntu3.4_amd64.deb ... Unpacking libpam-systemd:amd64 (245.4-4ubuntu3.4) over (245.4-4ubuntu3.3) ... Preparing to unpack .../4-systemd_245.4-4ubuntu3.4_amd64.deb ... Unpacking systemd (245.4-4ubuntu3.4) over (245.4-4ubuntu3.3) ... Preparing to unpack .../5-libsystemd0_245.4-4ubuntu3.4_amd64.deb ... De-configuring libsystemd0:i386 (245.4-4ubuntu3.3) ... Unpacking libsystemd0:amd64 (245.4-4ubuntu3.4) over (245.4-4ubuntu3.3) ... Preparing to unpack .../6-libsystemd0_245.4-4ubuntu3.4_i386.deb ... Unpacking libsystemd0:i386 (245.4-4ubuntu3.4) over (245.4-4ubuntu3.3) ... Preparing to unpack .../7-libnetplan0_0.101-0ubuntu3~20.04.2_amd64.deb ... Unpacking libnetplan0:amd64 (0.101-0ubuntu3~20.04.2) over (0.100-0ubuntu4~20.04.3) ... Preparing to unpack .../8-netplan.io_0.101-0ubuntu3~20.04.2_amd64.deb ... Unpacking netplan.io (0.101-0ubuntu3~20.04.2) over (0.100-0ubuntu4~20.04.3) ... Preparing to unpack .../9-linux-firmware_1.187.8_all.deb ... Unpacking linux-firmware (1.187.8) over (1.187.7) ... Setting up linux-firmware (1.187.8) ... update-initramfs: Generating /boot/initrd.img-5.8.0-38-generic I: The initramfs will attempt to resume from /dev/sda1 I: (UUID=b0e7eead-39f6-4e20-a3c9-c40f0823e8e7) I: Set the RESUME variable to override this. update-initramfs: Generating /boot/initrd.img-5.8.0-36-generic I: The initramfs will attempt to resume from /dev/sda1 I: (UUID=b0e7eead-39f6-4e20-a3c9-c40f0823e8e7) I: Set the RESUME variable to override this. Setting up libnetplan0:amd64 (0.101-0ubuntu3~20.04.2) ... Setting up libsystemd0:amd64 (245.4-4ubuntu3.4) ... Setting up libsystemd0:i386 (245.4-4ubuntu3.4) ... Setting up udev (245.4-4ubuntu3.4) ... update-initramfs: deferring update (trigger activated) Setting up systemd (245.4-4ubuntu3.4) ... Installing new version of config file /etc/dhcp/dhclient-enter-hooks.d/resolved ... Setting up netplan.io (0.101-0ubuntu3~20.04.2) ... Setting up systemd-timesyncd (245.4-4ubuntu3.4) ... Setting up systemd-sysv (245.4-4ubuntu3.4) ... Setting up libnss-systemd:amd64 (245.4-4ubuntu3.4) ... Setting up libpam-systemd:amd64 (245.4-4ubuntu3.4) ... Processing triggers for libc-bin (2.31-0ubuntu9.1) ... Processing triggers for man-db (2.9.1-1) ... Processing triggers for dbus (1.12.16-2ubuntu2.1) ... Processing triggers for initramfs-tools (0.136ubuntu6.3) ... update-initramfs: Generating /boot/initrd.img-5.8.0-38-generic I: The initramfs will attempt to resume from /dev/sda1 I: (UUID=b0e7eead-39f6-4e20-a3c9-c40f0823e8e7) I: Set the RESUME variable to override this. kaushal@kaushal:~$
