I would just like to know how to upgrade Xubuntu 18.04 to Xubuntu 20.04 Thank you
Thank you
I am certain the answer is on this site somewhere, but really quickly first make sure all current installed apps are up-to-date before upgrading.
Check what the update-manager is set for:
grep Prompt /etc/update-manager/release-upgrades
Make sure the return is Prompt=lts
Then from a terminal window type in:
sudo apt update
sudo apt upgrade
Then just run the following line to upgrade your distro to the next release:
do-release-upgrade
Terrance
  • 43,712
I would always read the release notes first for you release
https://wiki.xubuntu.org/releases/20.04/release-notes
Many flavors don't provide upgrade instructions, because their upgrade instructions are identical to the main Ubuntu system, so they instead refer you there
https://wiki.ubuntu.com/FocalFossa/ReleaseNoteshttps://wiki.ubuntu.com/FocalFossa/ReleaseNotes
(Releases that use Qt, such as Kubuntu, Lubuntu tend to have different commands, as they use different options (-m) to ensure screen saver/lock screen doesn't occur)
From a text terminal you can upgrade as Terrance describes, but you'll need to ensure screensaver or power saving functions don't kick in if using a GUI or problems may occur.
If using the GUI (including terminal on GUI) I'd suggest using command(s) provided in the main Ubuntu release notes (they disable screensaver/power etc during upgrade process). The instructions are found in the "Upgrading from Ubuntu 18.04 LTS or 19.10" section.
guiverc
  • 33,561
