A few days ago I installed Ubuntu 20.04.1 LTS. For some reason now it displays a black screen whenever I try to boot it up.
This is what I was doing before it happened.
I followed this guide to enable sound redirection on xrdp. Worked out fine and restarted the computer as was instructed at the end of the guide. However after it restarted it was stuck on the AsRock motherboard screen. I was unable to go into bios. I cleared the cmos and tried again. Bios works. The SSD containing ubuntu was still the boot drive- it even said ubuntu on it. I tried saving and exiting to no avail. Still stuck on AsRock screen.
In an attempt to fix it I just messed around with the bios settings and eventually it no longer showed AsRock. Instead it showed American Megatrends followed by a black screen. Whenever it is supposed to boot into ubuntu, it instead shows a black screen. Idk if the American megatrends thing is a big issue; if so please tell me.
I tried using boot repair multiple times on the installation usb, didn't work. I even tried checking the 'repair file system' and 'reinstall grub' options once- didn't work either. Here is the Pastebin for that. Grub doesn't show up (tried holding shift). It's just ami screen then black.
In case it expires: https://paste.ubuntu.com/p/Z5XnY4Gf2J/.
I have not overlooked the fact that it says:
Please do not forget to make your UEFI firmware boot on the Ubuntu 20.04.1 LTS entry (nvme0n1p1/EFI/ubuntu/shimx64.efi file) !
I'm not very familiar with how to do this, but then again every website suggesting boot-repair doesn't include this step. It's supposed to be just boot-repair, restart and boom fixed. Not the case for me.
In one of the online guides I saw that you could apparently reinstall ubuntu without losing data. That was my last resort as it mentioned it might not be able to restore the packages. I had no choice but to try it but to my disappointment there wasn't an option to do that... only wipe and reinstall.
Any help would be appreciated. Thanks.
UPDATE: I have tried rEFInd boot manager, didn't work. I also managed to somewhat reverse the american megatrends; it now says AsRock again. However this time it doesn't freeze- it turns black like with ami. I ran boot-repair again this time enabling most advanced options, still didn't work.
UPDATE 2: I have found the culprit. It was xrdp-pulseaudio-installer. Wiped the system and restored home, etc, var directories. Rebooted to frozen AsRock screen again. Booted into usb, deleted var/lib/xrdp-pulseaudio-installer and rebooted again. Grub showed up this time with a bunch of errors: stuff like "Failed to start (service name)". Will update again soon.
Final update: I have fixed the problem. Xrdp-pulseaudio-installer messed up the boot, but it was probably all the messing about I did in an attempt to fix it that made the situation worse. I deleted xrdp-pulseaudio-installer from backup, restored full backup, booted into tty, sudo and su were broken so I fixed those, did apt get update/upgrade/dist-upgrade to no avail. Reinstalled xorg and gnome- everything back to normal. Bad thing is now my system is messy cause I chose minimal installation.
