I was having issues like both Wifi and Ehthernet connection is getting disconnected suddenly. So, I searched about the problem in google and found this post about fixing the issues i'm having I tried the best to follow the post and comments to fix my issue but it didn't fixed my issue then at a point I came to a comment saying that uninstalling GNOME's Network Manager and installing WICD network manager can solve the issue and also he shared the command to install the WICD network manager but these command didn't worked just cause the commands were usable in Ubuntu 18.04 or older than that.
I came to realize reading this post that wicd was removed from the repositories because of Python 2 deprecation. After that I followed the post which is this one and tried to install the WICD by downloading the packages and installing manually there was these commands
mkdir -p ~/Downloads/wicd
cd ~/Downloads/wicd
wget http://old-releases.ubuntu.com/ubuntu/pool/universe/p/pygtk/python-gtk2_2.24.0-6_amd64.deb wget http://old-releases.ubuntu.com/ubuntu/pool/universe/p/pygtk/python-glade2_2.24.0-6_amd64.deb
wget http://old-releases.ubuntu.com/ubuntu/pool/universe/w/wicd/python-wicd_1.7.4+tb2-6_all.deb wget http://old-releases.ubuntu.com/ubuntu/pool/universe/w/wicd/wicd-daemon_1.7.4+tb2-6_all.deb wget http://old-releases.ubuntu.com/ubuntu/pool/universe/w/wicd/wicd-gtk_1.7.4+tb2-6_all.deb
sudo apt-get install ./.deb sudo apt-get install ./.deb # second time for correct configuration
to install WICD manually I ran all command but at last when I ran the command sudo apt-get install ./*.deb the terminal looks like this
lmao@lol:~/Downloads/wicd$ sudo apt-get install ./*.deb
Reading package lists... Done
Building dependency tree
Note, selecting 'python-glade2' instead of './python-glade2_2.24.0-6_amd64.deb'
Note, selecting 'python-gtk2' instead of './python-gtk2_2.24.0-6_amd64.deb'
Note, selecting 'python-wicd' instead of './python-wicd_1.7.4+tb2-6_all.deb'
Note, selecting 'wicd-daemon' instead of './wicd-daemon_1.7.4+tb2-6_all.deb'
Note, selecting 'wicd-gtk' instead of './wicd-gtk_1.7.4+tb2-6_all.deb'
The following packages have unmet dependencies: python-gtk2 : Depends: python-cairo (>= 1.0.2-1.1) but it is not installable Depends: python-gobject-2 (>= 2.21.3) but it is not installable wicd-daemon : Depends: python-dbus but it is not installable Depends: python-gobject-2 but it is not installable E: Unable to correct problems, you have held broken packages.
and I don't know how to fix the issue.
Note: I'm using Ubuntu 20.10.
N0rbert
  • 103,263
Mahir
  • 434
The above error output means that you need more dependencies to be installed manually on Ubuntu 20.10 for wicd:
cd ~/Downloads/wicd
wget -c http://old-releases.ubuntu.com/ubuntu/pool/universe/p/pygtk/python-gtk2_2.24.0-6_amd64.deb wget -c http://old-releases.ubuntu.com/ubuntu/pool/universe/p/pygtk/python-glade2_2.24.0-6_amd64.deb
wget -c http://old-releases.ubuntu.com/ubuntu/pool/universe/w/wicd/python-wicd_1.7.4+tb2-6_all.deb wget -c http://old-releases.ubuntu.com/ubuntu/pool/universe/w/wicd/wicd-daemon_1.7.4+tb2-6_all.deb wget -c http://old-releases.ubuntu.com/ubuntu/pool/universe/w/wicd/wicd-gtk_1.7.4+tb2-6_all.deb
for 20.10
wget -c http://archive.ubuntu.com/ubuntu/pool/main/libf/libffi/libffi7_3.3-4_amd64.deb wget -c http://archive.ubuntu.com/ubuntu/pool/universe/p/pygobject-2/python-gobject-2_2.28.6-14ubuntu1_amd64.deb wget http://archive.ubuntu.com/ubuntu/pool/universe/p/pycairo/python-cairo_1.16.2-2ubuntu2_amd64.deb wget -c http://archive.ubuntu.com/ubuntu/pool/universe/d/dbus-python/python-dbus_1.2.16-1build1_amd64.deb
sudo apt-get update sudo apt-get install ./.deb sudo apt-get install ./.deb # second time for correct configuration
N0rbert
  • 103,263
