I was trying to install Octoprint on Ubuntu 16.04 for my 3D printer, but I was having problems with the installation as it needed Python 3.6 and I only had Python 3.5
I searched how to install Python 3.6 on Ubuntu 16.04 and after various methods I managed to do install it and also managed to install Octoprint, although Octoprint would not run due to some errors.
Then I found that terminal in Ubuntu desktop would not work and after searching I found a website explaining how to fix it, using the following commands...
cd /usr/bin
sudo apt-get purge python3
sudo rm python3
sudo ln -s python3.5 python3
Source: https://medium.com/@aaditya.chhabra/not-able-to-launch-terminal-ubuntu-16-04-84de95ecdaa
The worry started when I could see it deleting lots of things which took around 5 minutes and when I opened Ubuntu desktop half of the icons were missing.
I managed to sort of fix it by running:
sudo apt-get install python3-all
Source: I deleted package 'python3' on Ubuntu and I have lost dashboard, terminal and Unity. Help me to restore my data please
I am now considering a fresh install this time using Ubuntu 20.04, as well as fitting larger HDD's in my server (Dell Poweredge T30) using RAID5.
However, I run Nextcloud on the server and dont want to loose the data stored in Nextcloud, but I cant access Nextcloud because Apache2 doesnt work anymore. Somehow the live folder of LetsEncrypt seems to have been deleted since removing Python3.
If I run...
systemctl status apache2.service
I get the following error...
    apache2.service - LSB: Apache2 web server
   Loaded: loaded (/etc/init.d/apache2; bad; vendor preset: enabled)
  Drop-In: /lib/systemd/system/apache2.service.d
           └─apache2-systemd.conf
   Active: failed (Result: exit-code) since Thu 2021-01-14 20:25:00 GMT; 11s ago
     Docs: man:systemd-sysv-generator(8)
  Process: 1140 ExecStart=/etc/init.d/apache2 start (code=exited, status=1/FAILURE)
Jan 14 20:25:00 HomeServer apache2[1140]: Output of config test was: Jan 14 20:25:00 HomeServer apache2[1140]: [Thu Jan 14 20:25:00.379373 2021] [so:warn] [pid 1151] AH01574: module dav_module is already loaded, skipping Jan 14 20:25:00 HomeServer apache2[1140]: AH00526: Syntax error on line 41 of /etc/apache2/sites-enabled/freeflyer.conf: Jan 14 20:25:00 HomeServer apache2[1140]: SSLCertificateFile: file '/etc/letsencrypt/live/freeflyer.dynu.net/cert.pem' does not exist or is empty Jan 14 20:25:00 HomeServer apache2[1140]: Action 'configtest' failed. Jan 14 20:25:00 HomeServer apache2[1140]: The Apache error log may have more information. Jan 14 20:25:00 HomeServer systemd[1]: apache2.service: Control process exited, code=exited status=1 Jan 14 20:25:00 HomeServer systemd[1]: Failed to start LSB: Apache2 web server. Jan 14 20:25:00 HomeServer systemd[1]: apache2.service: Unit entered failed state. Jan 14 20:25:00 HomeServer systemd[1]: apache2.service: Failed with result 'exit-code'.
I used the Ubuntu desktop backup tool (weekly), but it always gave warnings about not being able to backup a long list of files, presumably due to access rights and files being in use etc
When I try to restore the backup of /etc/letsencrypt there is still no live folder, the only folders are:
  • csr
  • renewal
  • renewl-hooks
How can I get Apache2 working so I can get Nextcloud back online ?
The backup tool is configured to backup the entire root folder, I did try to restore the root folder from a previous backup but it crashed and I had to power cycle the server.
In future I need to fix this backup issue because it has let me down in this instance.
John
